How to increase rev range?
Old Jul 5, 2007 | 05:25 PM
phenforum's Avatar
phenforum
Default How to increase rev range?
How can I help my VQ safely rev to 8-9k? What parts do I need specifically? I'm totally new to NA tuning. I hate to say it but I'm doing it mostly for the sound. If I wanted power I'd go FI with my Z.
Let me know, thanks.
Old Jul 5, 2007 | 05:28 PM
rythex's Avatar
rythex
cams, and valve springs, lifters and some sort of engine management.. and the most I think people crank the limiter up to is around 7500'ish...
any higher and you'll need to do even more expensive things.........
Old Jul 5, 2007 | 05:30 PM
Jonny Boy's Avatar
Jonny Boy
You should check out the high rev stroker kit from GTM. It should be exactly what you want.
Old Jul 5, 2007 | 05:31 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
a complete motor build from top to bottom....
Old Jul 5, 2007 | 05:44 PM
Nismo 350z's Avatar
Nismo 350z
+100. Otherwise just plan on revving up to 7100 if u have a non revup or 7500 if u have a revup using an ecu reflash. If u have a HR, there is nothing available to hit 8krpm....yet.
jimmyloose's Avatar
jimmyloose
The heads are still something that needs to be addressed first...
Old Jul 5, 2007 | 07:28 PM
TheCajunStyle's Avatar
TheCajunStyle
Don't do it unless you're building for this application.
Old Jul 5, 2007 | 07:29 PM
tienlo's Avatar
tienlo
If you're doing it for the sound, consider an engine swap. It would be Far more reliable, likely lighter, and similar cost to a rebuilt block.
Old Jul 5, 2007 | 10:28 PM
phenforum's Avatar
phenforum
What engine would I swap it to?
Old Jul 6, 2007 | 12:23 AM
bleunetizen's Avatar
bleunetizen
i just put jwt valve springs and tomei 268 cams.. with utec. wonder how high i can rev. it seems to hold 7000rpm fine
Old Jul 6, 2007 | 12:29 AM
Derek Dee's Avatar
Derek Dee
That made me laugh!
Old Jul 6, 2007 | 05:04 AM
Z1 Performance
Former Sponsor
with a stock bottom end, you're basically at your practical limit already (700-7200)
Old Jul 6, 2007 | 05:07 AM
bleunetizen
will it be safe to run 7200rpm all day ?
Old Jul 6, 2007 | 05:29 AM
Z1 Performance
Former Sponsor
it should be fine yes
Old Jul 6, 2007 | 09:07 AM
andyman4lyfee's Avatar
andyman4lyfee
with the rev extended via some kind of piggy back or whatever, arp rod bolts is all you need to rev to 7500rpm without breaking anything. now to make power upto that is a little different. i assume you have a regular vq35de
Old Jul 6, 2007 | 05:01 PM
Nismo 350z's Avatar
Nismo 350z
Yes. I take my non-revup to 7100 at least once a day.
Old Jul 6, 2007 | 07:21 PM
punish_her's Avatar
punish_her
Man I hate to see people destroying thier engines because it sounds cool. Man if you want revs stick with an RX7 or RX8. There is no practicle reason to waste all that time and money to rev that high if you just want the sound.
But here is some poison if you realy want to take it: reflash, EMS, Ferrea HD valve springs (the dual spring units), lighter Titanium valves & locators, HD stainless retainers. At least L19 head studs to prevent head lift, ARP fastners, at least eagle H beam rods and a set of leight weight forged pistons. Dont forget to destroke your rotating assembly (rods & crank). Knife edge and balance the crank while your at it.
Since your going for revs and not concerned about power, screw the cams and head work. The main key to reving high is a lighter mass and stronger parts, you add in a shorter stroke so its less distance to travel and you have it.
Now if you want power behind the NA you have ALOT more work to do (larger bore, bigger valves, higher compression pistons, the right cam to make power all the way up, head work out the wazoo, intake, headers, exhaust, cat delete, a good tune, and thats a start) You have ALOT of work cut out for minimal gains the route your going. Not saying NA is horrible its just a MOJOR uphill battle for power.
hulkout
Apr 28, 2017 09:00 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
