Engine Stays HOT!
Old Jul 6, 2007 | 09:20 PM
Abishop's Avatar
Abishop
Default Engine Stays HOT!
Hey Z Forum,
I had a question about engine tempatures. After running the car in 95 degree heat, the engine gets very hot. But even after letting the car sit in the garage with the hood open for 2 hours the engine is still to hot to touch for more then 5 seconds. I noticed this when i was NA too. Maybe its me but i think these engines hold their heat for a long time. Does anyone have any good ideas for cooling the car down other then a bigger radiator, fans, water wetter, ect? Like removing the engine cover, Cooling plate, Intercooler Sprayer?
Have you guys had this problem?
Old Jul 7, 2007 | 05:41 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you've got a turbo car, running in hot temps, in a very closed engine environment.....its supposed to be hot, nothing to worry about.
Old Jul 7, 2007 | 05:48 AM
twenzel's Avatar
twenzel
Parking your car in the garage with no air flow on a hot day, hood up or not, your engine will stay hot for a few hours at least
Old Jul 7, 2007 | 11:46 AM
Abishop's Avatar
Abishop
Good to know thanks guys!
I have a greddy cooling plate, is there any proof that this really helps cool the engine?
Old Jul 7, 2007 | 12:25 PM
THE ROADSTER's Avatar
THE ROADSTER
I have the Veilside hood and it helps alot, you can actually see the heat disburst through the vents.
Old Jul 7, 2007 | 12:27 PM
black06z's Avatar
black06z
Turbo timer and vented hood?
Old Jul 7, 2007 | 12:28 PM
fast kiwi's Avatar
fast kiwi
+1^^^
Old Jul 7, 2007 | 01:21 PM
Z1 Performance
Former Sponsor
the greddy air panel, like any air panel, looks nice - thats about it
Old Jul 8, 2007 | 07:22 AM
Abishop's Avatar
Abishop
^ thats what i thought.
Even with the turbos being water cooled, do you still need a turbo timer?
Old Jul 8, 2007 | 07:29 AM
Z1 Performance
Former Sponsor
a turbo timer is a convenience mod, not a security one. After a spirited run in the car, you can make sure your last couple minutes of driving are non boosted, or just sit in the car after running it hard for a couple minutes before shutting off. The turbo timer simply allows you to leave the car running without having to sit in it.
Old Jul 8, 2007 | 02:46 PM
Abishop's Avatar
Abishop
I see. But letting the car sit at idle is supposed to keep my engine temps down? I can see it helping the turbos cool down but wouldn't it make my engine hotter?
Old Jul 8, 2007 | 06:17 PM
Z1 Performance
Former Sponsor
who cares how hot the engine gets? It's an engine...it's supposed to be hot when running.
The turbo timer keeps the car running after you turn the key off...the purpose is to keep the oil circulating a bit longer so it doesn't just sit and "coke" in the lines or housing of the turbo. Like I said, easing up on the last few minutes of a hard driving session does the same thing
Old Jul 8, 2007 | 07:24 PM
THE TECH's Avatar
THE TECH
It's not for cooling the engine, it is for directing the airflow toward the radiator more.
Old Jul 8, 2007 | 07:25 PM
THE TECH's Avatar
THE TECH
No, it is not to help cool the engine down. It is supposed to do what Adam said above.
Old Jul 8, 2007 | 07:44 PM
Abishop's Avatar
Abishop
ohh i see. Thanks for the info guys im kind of a turbo noob....
Old Jul 9, 2007 | 04:07 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Andrew... IM me next time your online.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
SharX59
Sep 30, 2015 10:54 AM
