soft clutch
Old Jul 16, 2007 | 01:57 PM
TriniBoosT's Avatar
TriniBoosT
Default soft clutch
is anyone having problem with their clutch pedal getting soft(all stock), "or having to step on it at least half way down to the floor board before you get any pressure" - this happens to me once in a while only when i am in heavy traffic or when stopping and going thru a buzy parking lot.
Old Jul 16, 2007 | 03:00 PM
drifter23's Avatar
drifter23
I have that exact same problem with my stock clutch. And have it with my current JWT setup. Going to take it to the dealer tomorrow to see what they can do to fix it. Does your clutch get sticky (clutch sticks to the floor) sometimes when you are in stop and go traffic. I will post up what the dealer says when I get some info from them.
Old Jul 16, 2007 | 03:02 PM
MIAPLAYA's Avatar
MIAPLAYA
Typically this is a sign of your clutch fluid boiling or having air in the hydraulic clutch line. Try bleeding it or replace it with a SS line and some high temp fluid.
Old Jul 16, 2007 | 05:55 PM
TriniBoosT's Avatar
TriniBoosT
yes i have the same problem with the pedal sticking half way down- im dropping mine off to baker jackson north in the morning.
Old Jul 17, 2007 | 08:29 AM
drifter23's Avatar
drifter23
Dealer told me it is either the master cylinder/slave cylinder that has gone bad. Air bubbles in the clutch line or clutch fluid boiling. They are going to confirm my problem later on today. Will keep you posted once I get a response from them.
Old Jul 17, 2007 | 09:51 AM
VO...'s Avatar
VO...
Administrator
try bleeding any foreign air out of your system. this might help..
Old Jul 17, 2007 | 12:28 PM
TriniBoosT's Avatar
TriniBoosT
the dealer finally duplicated the problem today - but new problem - the said the car is too low to lift up with thrie lifts -
Old Jul 17, 2007 | 01:28 PM
drifter23's Avatar
drifter23
Dealer just called me and they test drove my car and the problem occurred. They are replacing my clutch master cylinder and slave under warranty. And they said they are 98% sure the problem will be resolved. Hope the item's they are replacing will cure my problems. Only thing is the parts are on order and my car is staying overnight at the dealership.
Old Jul 17, 2007 | 02:07 PM
TriniBoosT's Avatar
TriniBoosT
which dealership did you take it to ?
Old Jul 17, 2007 | 02:18 PM
drifter23's Avatar
drifter23
I live in San Jose, CA. and took it to Falore Nissan in Sunnyvale California.
Old Jul 17, 2007 | 10:06 PM
terrasmak's Avatar
Mine gets soft all the time , i have a SS line and end up bleeding it monthly.
Old Jul 18, 2007 | 05:30 AM
TriniBoosT's Avatar
TriniBoosT
i thought the dealer would say the master or slave cylinder needed to be replaced , but instead they claimed its the clutch pedal assembly needs to be replaced. i told them if it didnt work ill be back again - they are paying for it so im not worried
Old Jul 18, 2007 | 09:28 AM
VO...'s Avatar
VO...
Administrator
glad to see you're getting it worked out...
Old Jul 18, 2007 | 10:55 AM
simonfencer's Avatar
simonfencer
A mushy clutch like that can be a little dangerous too. Many years ago now (just counted, makes me feel old, lol) I had a Fiero GT that had a clutch master cylinder go bad. After it pulled away all by its self once, I learned very quickly to not sit in gear for any longer than absolutely necessary. Needless to say I got it fixed quick.
Old Jul 24, 2007 | 06:52 PM
drifter23's Avatar
drifter23
Got my car back from the dealership. Clutch pedal does not stick to the floor anymore and the clutch grabs really well. On the paper work it stated they replaced the clutch master cylinder and slave. And they also found a small leak coming from the old master cylinder.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
