Car stalled out for first time tonight.
Old Jul 20, 2007 | 08:49 PM
moog's Avatar
moog
Default Car stalled out for first time tonight.
03 G35 coupe 5AT
80k miles
Vortech supercharger installed about 3k miles ago
No problems until tonight. I was leaving the shop and headed to the gas station to fill up on gas. The car had the low fuel light lit for a few miles. As I pull into the gas station driveway the car loses power and immediately dies. I put it into neutral and turn the car back on. It fires back up w/ no problem. So I'm like huh? and just fill it up full. As I'm pulling out of the gas station, while i'm turning onto the small side street the car immediately dies again. Turn the car back on and it fires back up w/ no problem.
So I was creeped out and drove back to GS Motorsports. As I pull into the shop driveway the car dies a third time. We do a bunch of tests, check for vacuum leaks, check for anything out of the ordinary and didn't find anything. We decide to try and raise my idle by adjusting the throttle/gas pedal drive-by wire sensor. The sensor seemed almost loose and you could just wiggle it, and the car would zoom up in revs. We were able to twist/turn it a certain way to where the idle rested at around 750rpm. Before it was around a low 600ish-650ish. I drove the car back home about 25 miles w/o any problems.
Question is...do you guys think this was all a low idle issue? or could it possibly be the loose sensor for the gas pedal? I'm not even sure how "loose" its supposed to be. Ever since the supercharger install, the idle has been low. But the car had never stalled out until tonight. I'm wondering if I need to get a new sensor for the gas pedal.
Old Jul 21, 2007 | 07:09 AM
HondaKiller's Avatar
HondaKiller
fuel pump issue? Clogged line perhaps? I guess if the test didn't pick up anything, it's a process of elimination now. See if the problem persist and move on from there i guess. Stalling out is the worst feeling when it comes to problems, good luck with things partner.
Old Jul 22, 2007 | 07:51 AM
Corradoslc7's Avatar
Corradoslc7
Sounds like your problem was a loose dbw sensor, which they fixed.
Old Jul 22, 2007 | 10:16 AM
Dmorrisjr350z's Avatar
Dmorrisjr350z
i would say it was the sensor also, typically they raise your rpms when you go FI correct?
Dave
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
Mattg350z
Oct 2, 2015 06:51 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
