UR Crank Pulley Belt Squeal
Old Jul 22, 2007 | 01:32 PM
Armitage's Avatar
Armitage
Default UR Crank Pulley Belt Squeal
I can't seem to get rid of it, though I'm going to try lubricating the pulley next. I tried tightening the belts today, didn't seem to help. Its usually only on startup, though if I have the AC running it seems to happen as well, especially when turning the wheel pretty far (utilizing power steering).
I don't think the belts are loose, there is not a lot of play with them. What else could it be?
Old Jul 22, 2007 | 03:11 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
don't use any lube.... bad idea
simply, either your belts are worn, or not tight enough. It takes making the belt slightly tighter than normal to make them not squeal but trust me, that's the problem
Old Jul 22, 2007 | 03:19 PM
gqong's Avatar
gqong
sounds like you need to tighten them some more
Old Jul 22, 2007 | 04:06 PM
Mathys's Avatar
Mathys
Can you tighten the belts without taking away the radiator fan etc? I have the same sound with my UR pulley set and want the dealer to tighten the belts when I have my upcoming oil change. Can you just reach with a socket extension or something to tighten them? I don't want to be charged too much for tightening them if it's an easy job.
Old Jul 23, 2007 | 01:21 PM
Armitage's Avatar
Armitage
Yes the bolts are easily accessible after removing the plastic shielding underneath. They are 11mm bolts I believe and sit in an assembly underneath your power steering and AC pullies I think. Both face directly at the ground.
I'm going to give tightening them another shot then and avoid the lubrication. I've only had the belts on maybe two months, so I can't imagine they are worn out, especially since they are Gates belts and considered very good belts. But if it continues, I will buy new belts and start over.
Thanks!
Old Jul 24, 2007 | 01:57 AM
G350ZTT's Avatar
G350ZTT
Good luck...i have the same prob. I can't tighten them any more and it still squeeeels like a pig. And when the AC is on.....OMG
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
