Help Me
Old Jul 23, 2007 | 03:37 PM
reworix's Avatar
reworix
Default Help Me
should my 03 z use all the oil within the oil change?? i will get the oil changed an before it is ready for another oil change the oil barely reads on the dip stick.. is this normal??
Old Jul 23, 2007 | 03:42 PM
RED HOT Z's Avatar
RED HOT Z
your probably burning oil. Its not normal.
Old Jul 23, 2007 | 03:43 PM
zand02max's Avatar
zand02max
you have a problem, serious problem!
Old Jul 23, 2007 | 03:59 PM
reworix's Avatar
reworix
so if i take it to the dealer how will they fix this problem? its still under warranty
Old Jul 24, 2007 | 03:51 AM
zand02max's Avatar
zand02max
I don't think its under warranty unless you have an extended warranty! Call the DEALER!
Old Jul 24, 2007 | 05:30 PM
reworix's Avatar
reworix
nah my car is still under warranty it only has 51k miles on it i got til a 100k or 2013 which coomes 1st, will they give me a new motor???
Old Jul 24, 2007 | 05:47 PM
A car with only 51,000 miles should not burn oil. You know that.
Old Aug 17, 2007 | 11:13 AM
reworix's Avatar
reworix
Default i went to the dealer today
i went to nissan about my 03 z consuming oil between oil changes not just a lil oil but so much it dosent show on the dip stick.. so they say they were giving new motor bc of the problem and now they found out that its the valve covers... now how true is this?? an should i try to get a new motor or just let them do the change????
Old Aug 17, 2007 | 12:34 PM
qxz9027mkii's Avatar
qxz9027mkii
Does the car leak oil, if it doesn't leak at all then the engine consumes oil, and thats not good but any way you have a long warranty IMO do as they recommend if it solves the problem thats good, if it doesn't let them change the motor,,,
Old Aug 17, 2007 | 12:38 PM
fast kiwi's Avatar
fast kiwi
oh ooooooh....
Old Aug 17, 2007 | 01:11 PM
TENGAI's Avatar
TENGAI
Valve covers??? This is news to me. Since when did valve covers have anything to do with the oil consumption problems reported with our engines?
Old Aug 17, 2007 | 01:29 PM
HondaKiller's Avatar
HondaKiller
i bet you have oil in your spark plugs. A leaky valve cover would definatly show signs of oil on the ground. Honestly though, i have an '03 base with 51300 on it, and it doesn't leak or burn a drop. I do the oil changes myself, so i would notice. Good luck with things, i wouldn't say changing the valve cover is such an "engine swapping" ordeal, but free is free, take what you can get.
Old Aug 17, 2007 | 04:25 PM
cheshirecat79's Avatar
cheshirecat79
An '03 burning oil like that is definitely not normal.
(super expert opinion)
Old Aug 17, 2007 | 05:06 PM
reworix's Avatar
reworix
well the dealer says that it has happend alot among 03s but something to do with the valve covers cause it to burn oil or something like that..something to do with the the inside material causes it to burn... i dont know i dont think it will help but whatever as long as it stop.. and my warranty is 100,000 miles or 2013 and i have 62000 on a enth.
Old Aug 17, 2007 | 05:08 PM
reworix's Avatar
reworix
oh yea also the oil isnt leaking anywhere i checked everything..
Old Aug 17, 2007 | 05:10 PM
zand02max's Avatar
zand02max
10 year warranty, did you purchase a 6 year warranty in 07 for an 03 model? Something doesn't sound right!
Old Aug 17, 2007 | 05:55 PM
reworix's Avatar
reworix
i dont kno but they gave me papers that say 100k or 2013 so what ever its on paper so i got proof
Old Aug 17, 2007 | 05:57 PM
zand02max's Avatar
zand02max
How much extra was the extended warranty?
Old Aug 17, 2007 | 06:05 PM
reworix's Avatar
reworix
it didnt cost anything
Old Aug 17, 2007 | 07:06 PM
zand02max's Avatar
zand02max
I highly doubt that!
