Question about crush washers
Old Aug 7, 2007 | 04:24 PM
redmike_02's Avatar
redmike_02
Default Question about crush washers
What size are the crush washers for the tranny and diff? Are they the same as the one for the oil drain plug?
I couldn't find it anywhere and the dealer wasn't any help. Trying to change the fluids soon and need to know.
Old Aug 7, 2007 | 06:32 PM
redmike_02's Avatar
redmike_02
Help!
Old Aug 7, 2007 | 06:39 PM
OCG35's Avatar
OCG35
a crush washer/crush sleeve is used to put tension on the pinion bearing... it's not really a washer to install with the drain plug... it sounds like your looking for a regular washer right?... You won’t need a crush washer/sleeve unless you are rebuilding the pumpkin... Actually I don’t even remember if the differential drain plug has an additional washer… I know the motor oil drain plug does.
Old Aug 7, 2007 | 07:28 PM
DavesZ#3's Avatar
DavesZ#3
Accord to the FSM, the trans has a gasket, not a crush washer. Same goes for the diff.
Check out these two pages, you should be able to find the part #s of the gasket/seal/washer/etc.
Trans:
http://www.courtesyparts.com/betasit...5_778_792.html
Diff:
http://www.courtesyparts.com/betasit...5_778_798.html
Old Aug 7, 2007 | 07:42 PM
OCG35's Avatar
OCG35
Trans:
Diff:
what are you looking at though?... He's wanting to replace his fluid... looks to me like part number 38351B for is a washer for the diff drain plug and 32103A is a washer for the trans drain plug...
Old Aug 7, 2007 | 07:49 PM
OCG35's Avatar
OCG35
the crush washer/sleeve (Nissan calls spacer housing) is 38165... not applicable to OPs project (that I can tell).
Old Aug 8, 2007 | 05:06 AM
Tac-M's Avatar
Tac-M
Just don’t worry about them, if you are doing your first change, you'll be fine with the ones that are on it now.
Old Aug 8, 2007 | 01:48 PM
redmike_02's Avatar
redmike_02
Trans:
Diff:
It's just the washer on the fill and drain plugs. I'm just changing the fluid.
burglapfd
Dec 6, 2020 01:04 PM
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
