Best place to get heads ported and assembled?
Old Aug 12, 2007 | 03:46 PM
camthman's Avatar
camthman
Default Best place to get heads ported and assembled?
What the title says. Blew a head gasket and figure I might as well send the beasts (heads) off for porting and assembly. Where are the best/cheapest places to send them? Thanks.
Old Aug 12, 2007 | 05:36 PM
failsafe306's Avatar
failsafe306
Um what lead you to believe your headgasket is blown? Coolant overflow, white smoke, what? I have a hard time seeing the headgasket blew on an NA car...
To answer your question, try GT Motorsports in socal, but be prepared to wait a while and spend alot of money. But in the end you will be happy with their work.
Old Aug 12, 2007 | 05:43 PM
HDPDZO6's Avatar
HDPDZO6
Overheating a motor will blow a head gasket very easily. It does happen and isn't that uncommon.
Old Aug 12, 2007 | 08:52 PM
go-fast's Avatar
go-fast
depends on what you want the heads to do,porting for cfm at high lift #s will hurt low,midrange for a higher peak hp #.
Old Aug 13, 2007 | 08:09 AM
camthman's Avatar
camthman
Overheated and blew the headgasket. Thanks.
Old Aug 13, 2007 | 08:36 AM
HDPDZO6's Avatar
HDPDZO6
Been there done that. Were the heads warped as well?
Old Aug 13, 2007 | 08:38 AM
HondaKiller's Avatar
HondaKiller
best and cheapiest shouldn't be used in the same sentence. Sorry to hear partner, GT Motorsports will fix you up.
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
