Changing Transimission and diff fluid.
Old Aug 21, 2007 | 07:21 AM
Spec_Tacular's Avatar
Spec_Tacular
Default Changing Transimission and diff fluid.
Ok so Nissan recommends using 2.9L GL4 75w-85 or 75w-90 for the transmission and 1.4L GL5 80w-90 for the differential. I want to change to Motul fluid. When changing to Motul would it be best to stick with those ratings? Would it be bad to use the GL4 in the rear diff? Also on www.mynismo.com they recommend using friction modifier I am not sure what it is because I don't see it on there site?
Thanks guys!
Old Aug 21, 2007 | 08:34 AM
SpeedRcr's Avatar
SpeedRcr
75w90 is what i ran in both the diff and trans. I ended up going back to nissan oem fluid for the trans but I am still running motul in the diff
Old Aug 21, 2007 | 08:41 AM
350ZV3's Avatar
350ZV3
Tranny uses Motul Gear 300V 75W-90 100% Synthetic.
The differential depends on what kind you have?
If its a clutch style like my Nismo Differential use: Motul 90PA limited-Slip Differential 2 Liter already has (friction modifier) additives in it and youll use about 85% of the bottle and 5% to flush old fluid out.
If its a non clutch style gear box youll use the Motul Gear 300V 75W-90 100% Synthetic for tranny and differential.
Check out http://www.forgedperformance.com/store/home.php?cat=278 for prices and mention 10% discount for members here.
Old Aug 21, 2007 | 09:26 AM
Spec_Tacular
I have the stock Viscous LSD. Also I heard not to put GL5 in the tranny but they recommend it for the diff? It's ok to run 75w-90 when Nissan recommends 80w-90?
Old Aug 21, 2007 | 09:49 AM
Resolute's Avatar
Resolute
Don't run a GL4 gear oil in the diff. It needs a GL5 for hypoid gear use. The oils are not backwards compatible, so do not use a GL5 oil in the tranny unless it is also GL4 spec. There's a reason the manual states what it does, just stick to it.
Will
Old Aug 21, 2007 | 10:44 AM
RebelinRI's Avatar
RebelinRI
I have Motul oil in both Tranny and Rear end. I will change out the tranny oil for sure. Ever since I put it in, when it's cold out (winter time) it whines like a school girl until warm and I also get a little grind going into second gear. Hopefully I'm the only one since this is supposed to be "great stuff". Going back to OEM.
Old Aug 24, 2007 | 04:20 PM
gothchick's Avatar
gothchick
Tranny - 75w90 GL-4. Took about 3.75 qts.
Diff - 75w90 GL-5. Took just under 2 qts.
Running Amsoil in both.
Tranny feels good. Still whines up through 3rd gear like it did when it was new (syncros).
Less notchy than oem, but still a little notchy until fully warmed up. Then it's like a hot knife through butter~ :-)
Old Aug 26, 2007 | 05:00 PM
psowacki's Avatar
psowacki
Default royal purp
i got Royal Purple 80 90 in my diff and in my tranny and it runs like buttah,lol
Old Aug 27, 2007 | 12:23 PM
VO...'s Avatar
VO...
Administrator
Answer to all your questions... That'll be $19.95 to my paypal account..
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/131098-changing-the-differential-transmission-oil.html
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
