Question about spark plugs, wires, and other tune-up parts...
Old Aug 29, 2007 | 08:19 AM
NiZmO350's Avatar
NiZmO350
Question Question about spark plugs, wires, and other tune-up parts...
This has probably been posted or asked before, but I am getting ready to do a tune up and would like to know what is the best parts I can get (if I even have any options) and what I will need... my first time working on my Z alone... LOL. So please be nice...
1 - ignition wires
2 - spark plugs
3 - distributor cap (should I just buy the stock replacement or is there something better out there?)
4 - or whatever else...
Old Aug 29, 2007 | 08:30 AM
mpowers's Avatar
mpowers
Your going to want to go to summit racing and pick up some 22mm wires around 200 bucks, also get the high performance cap and rotor for another 75 buck.
There are lots of plugs to chose from but go with the a/c delco gold, these are worth 5-6hp over stock around 25 each.
Should take no longer than an hour to replace all.
Good luck,
Mike
Old Aug 29, 2007 | 08:32 AM
blasian's Avatar
blasian
There are no spark plug wires and there is no distributor.
I thought the same when changing the plugs lol.
Old Aug 29, 2007 | 08:40 AM
KManZ's Avatar
KManZ
Good luck,
Mike
5-6 hp with just spark plugs? If anything you will simply be recovering the hp you lost due to the worn out plugs.
OP: go with OEM, save yourself the money.
Old Aug 29, 2007 | 08:57 AM
jtabraham's Avatar
jtabraham
The Z uses direct INGNITION which means you have a coil pack for each cylinder...this means no distributor and no spark plug wires.
As far as plugs are concerned, you could stick with OEM. I bought some NGK Iridiums from Adam and Kwame @ Z1 and are very happy with them.
Changing out the plugs isn't too bad. I found the hardest thing was to get enough room for my hands to be able to unclip the wiring harnesses from each coil pack so I could remove them.
Also make sure you have a good 3/8" extension bar to use.
edited: Mistakenly wrote injection instead of ignition
Old Aug 29, 2007 | 10:22 AM
SpeedRcr's Avatar
SpeedRcr
Good luck,
Mike
we have coil packs so no need to change wires and we dont have a cap or rotor that comes with a distributor...just change the plugs
Old Aug 29, 2007 | 10:34 AM
sloppymax's Avatar
sloppymax
sarcasm>*
Old Aug 29, 2007 | 10:37 AM
jtabraham's Avatar
jtabraham
Originally Posted by sloppymax
sarcasm>*
Old Aug 29, 2007 | 10:45 AM
zdrift78's Avatar
zdrift78
Originally Posted by jtabraham
The Z uses direct injection which means you have a coil pack for each cylinder...this means no distributor and no spark plug wires.
I think you mean direct IGNITION...
Old Aug 29, 2007 | 10:48 AM
mpowers's Avatar
mpowers
Your Z's either a Diesel or a Mazda to have direct injection.
My guess yours is a diesel model.
Maybe you can help him change his parts.
Good luck with all that,
Mike
Old Aug 29, 2007 | 10:50 AM
jtabraham's Avatar
jtabraham
whoopsie doodle. I can speak dem dare en-ga-lish.
Old Aug 29, 2007 | 10:52 AM
jtabraham's Avatar
jtabraham
Mike
Yep...stuffed a 7.3L turbo Diesel
Thanks for the correction
Old Aug 29, 2007 | 11:31 AM
n1sm0r's Avatar
n1sm0r
Good luck,
Mike
This is a perfect example of why you shouldn't believe everything people say on the forums
Old Aug 29, 2007 | 11:39 AM
jtabraham's Avatar
jtabraham
To the OP: I took my time doing it and it took maybe 90 minutes total. Like I said in a previous post, I would recommend getting a long 3/8" extension and using a torque wrench to tighten everything back down to spec. While you're under the hood, it may be a good idea to clean your throttle body and MAS as well.
Old Aug 29, 2007 | 11:54 AM
redkaz04's Avatar
redkaz04
wow, terrible advice........this is why forums have no credibility
Old Aug 29, 2007 | 12:20 PM
jtabraham's Avatar
jtabraham
You'll get bad advice from all facets of life. I'm sure everyone has been to a mechanic or dealer that had no clue what they were talking about.
The great things about forums are that bad information is usually addressed pretty quickly. Case-in-point: I erroneously wrote Direct Injection instead of Direct Ignition, and two members were able to quickly point out that error.
Old Aug 29, 2007 | 12:56 PM
sloppymax's Avatar
sloppymax
i had an inclination that mpowers was being sarcastic since a quick check under the hood would have revealed the answer the OP.
Old Aug 29, 2007 | 01:06 PM
I would go with the JDM distributor cap.
Old Aug 29, 2007 | 04:02 PM
wilson7136's Avatar
wilson7136
Change the grease on the belts while you are under the car unhooking he spark plug wires. It is easier that way. Don't forget about the air in the shocks or washers on the valve stems.
And least I forget............the bulbs in the spoiler.
Old Aug 29, 2007 | 04:44 PM
failsafe306's Avatar
failsafe306
But the JDM version is on the opposite side of the motor, it won't fit!
OP- make sure you pick up some carb cleaner for your carburetor! JK!
