anybody know how to remove u joints
Old Sep 2, 2007 | 05:43 AM
nathanwl2004's Avatar
nathanwl2004
Default anybody know how to remove u joints
were replacin the 6MT trans, but we can't figure out how to take the u joints apart.
if anybody else has done this how did you align the pilot shaft with the clutch assembly?
Old Sep 2, 2007 | 06:37 AM
fklentz's Avatar
fklentz
Disconnect the drive shaft at the differential, pull drive shaft out. If you're replacing the clutch you will need an alignment tool to align the clutch disc with the pilot bushing before tightening down the pressure plate. If you can get a pilot shaft from an old transmission they work great, if not most part stores have them.
Old Sep 2, 2007 | 06:49 AM
arizzee's Avatar
arizzee
according to the service manual, if there's play in the u-joints, replace driveshaft lol. So there's no factory approved method to remove them.
Old Sep 2, 2007 | 08:21 PM
i8acobra's Avatar
i8acobra
4 bolts hold the DS to the rear end. Remove these. Lower the back of the driveshaft enough to slide it back. The front of the DS will slide out of the tranny. To line up the clutch, you use a clutch alignment tool. Your clutch should come with one.
Old Sep 2, 2007 | 10:22 PM
nathanwl2004
thanks guys, actually my tranny went out and my warrantee is toast, so we've been doin a whole tranny swap.
Old Jul 7, 2008 | 09:17 AM
Car vs. Driver's Avatar
Car vs. Driver
Bumping an old thread ... what's the trick to getting the four 17mm rear bolts loose on the drive shaft? I cannot for the life of me get them to budge and there's no room to get an impact wrench in there.
Old Jul 7, 2008 | 10:30 AM
cellude's Avatar
cellude
I used an extension on my impact to get those loose.
Old Jul 7, 2008 | 11:00 AM
Car vs. Driver
Yep, I finally got them off with a long socket wrench and a swivel joint.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
