Checking wheel bearing
Old Sep 2, 2007 | 09:53 AM
redline350ZZ's Avatar
redline350ZZ
Default Checking wheel bearing
How difficult is it to change out / repair the passenger side rear wheel bearing? After ripping my brakes apart I think the noise has to be from there or the parking brake assembly.
Old Sep 2, 2007 | 10:02 AM
redline350ZZ
NM I found some info and the noise gets quieter as I drive faster so it must be something else.
Old Sep 2, 2007 | 05:04 PM
Q45tech's Avatar
Q45tech
One puts the car of lift and listens with a stethoscope as the rear tires are driven slowly up and down to speed...............front is spun up with a on car balance machine.
Old Sep 2, 2007 | 05:11 PM
redline350ZZ
I already learned its the bearing and I'm trying to find one. Everything is apart.
Old Sep 2, 2007 | 08:49 PM
n1sm0r's Avatar
n1sm0r
It's pretty easy. You need a hub puller and a very large axel nut socket (don't recall the size, but they're large.). I bought mine at Kragen for about $12. Have a huge breaker bar (I used a craftsman 18inch breaker with a 42 inch pipe on the end and had no problem breaking it loose). Don't overtorque it down when you tighten it down because the nut can crush the dust shield on the bearing, so use a torque wrench. The bearings are pre-greased but I added more anyway just to be safe. I'm not too familiar with the procedures for the rear bearings, but it should be fairly simple with a big enough breaker bar and elbow grease.
Obadabot
Jun 18, 2023 11:31 PM
