Any tips on how to take out the pilot bearing in the tranny?
Old Sep 6, 2007 | 07:50 PM
SuperBlack350z's Avatar
SuperBlack350z
Default Any tips on how to take out the pilot bearing in the tranny?
Anyone know tips on how to take this peice out easily? Thanks. Also hot to put it back in.
Old Sep 6, 2007 | 07:56 PM
SuperBlack350z
bump
Old Sep 7, 2007 | 05:23 AM
gothchick's Avatar
gothchick
18. Now there is one small little piece left, the pilot bushing. Most clutch sets include this so you might as well change it. The service manual says to use a special tool, use it if you have it. I used an old trick to get this guy out, fill in the hole with some thick grease and with the clutch alignment tool begin tapping it into the hole, (I removed the plastic ring on mine). Eventually the pressure from the grease will pop it out. I didn’t replace the pilot bushing as it looked great! This is rare to wear out!
For the full thread:
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/292139-diy-clutch-install-part-ii-jwt-clutch.html
Old Sep 7, 2007 | 05:27 AM
SuperBlack350z
thanks, i already read that but have no clue on how that would work. The pilot bearing is on there pretty good. I asked soem local mechanics and they same most cars are really tricky as well to get out.
Old Sep 7, 2007 | 05:32 AM
phreaktor's Avatar
phreaktor
Design Engineer
Basically, you need an open ended 17mm wrench and a hacksaw. Don't worry you aren't cutting anything with the hacksaw. It's just for show. Stick the open end of the wrench into the little gap between the transmogrifier output shaft and the bellhousing adapter. If you give it a sharp twist, you should end up with a handful of bearing grease and a lot of little gold pins and rods. Use the bearing grease to lubricate the clutch alignment tool and insert it into the pinion carraige. If you are careful you may just be able to pull out that thing you were asking about.
Old Sep 7, 2007 | 05:35 AM
SuperBlack350z
that made a bit more sense. Thanks for the tip. I'm goign to try it today. The car is on my lift. I'm trying to finish it before the weekend ends.
Old Sep 7, 2007 | 05:36 AM
gothchick's Avatar
gothchick
Here's another thread with pics... This guy is really inspirational with his mechanical skillz. :-)
https://my350z.com/forum/showpost.ph...5&postcount=36
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
