Carbonetics Twin Carbon Clutch Engagement problems
Old Sep 29, 2007 | 10:34 AM
noer's Avatar
noer
Default Carbonetics Twin Carbon Clutch Engagement problems
Hi Guys,
I had a Carbonetics Twin Carbon Clutch installed. What I noticed is that when my car gets hot the engagement point it much lower and when it's cold it is higher. Could it be my master cylinder that is problematic? I only have 14000miles on my 05 350Z. My tuner did some mod and placed a stopper below my clutch so that my clutch travel is much less. We took car for a spin and it works well.. I didnt drive it long though.. only 15km since he added the stopper. I a bit worried about the stopper cause if the engagement point is lower then I will not beable to change gears.. anyone did such a mod on their Z. Also could it be a master cylinder problem.
Regards
Old Sep 29, 2007 | 06:19 PM
Zivman's Avatar
Zivman
Originally Posted by noer
Hi Guys,
Regards
never heard of such a mod. I have the ats twin and my engagement point is on the upper half of the pedal swing. I haven't experienced any change in engagement point
Old Oct 4, 2007 | 09:04 AM
wstwd's Avatar
wstwd
yeap i had same problem too.
we have changed master cylinder and slave cylinder
there is a repair kit for them and its costs only 25-30 usd .
and buy steel clutch line .
Old Oct 4, 2007 | 03:19 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Sounds like the fluid is getting hot. If you aren't already, try using a braided stainless clutch line with heatwrap to keep heat out. Also, I would be curious about the clutch mod that was done.
Old Oct 5, 2007 | 06:05 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
also make sure someone is bleeding it with a vacuum bleeder and the traditional way, sometimes air will just get trapped in there. they are a pain to bleed sometimes
Uriyo_
Sep 8, 2021 08:46 AM
