Clutch pedal shudders when pressed in; intermittent
Old Sep 29, 2007 | 11:50 AM
failsafe306's Avatar
failsafe306
Question Clutch pedal shudders when pressed in; intermittent
Well, title pretty much says it. About 75% of the time when I push in the clutch pedal, I feel a vibration or shudder in the pedal. But sometimes, it's a smooth as butta. The last few times I also noticed on cold starts only, a high pitched whining noise (sounds like metal on metal) coming from the clutch when I pushed the pedal in, but within a few seconds, it went away.
Sound like a throwout bearing problem?
Oh, and I searched
Chris
Old Sep 29, 2007 | 06:20 PM
Zivman's Avatar
Zivman
Oh, and I searched
Chris
First thought that came to mind was the throwout bearing
Old Sep 29, 2007 | 06:21 PM
failsafe306
That's what I'm thinking too. But what exactly could be physically causing the pedal vibration?
Old Sep 29, 2007 | 11:40 PM
SuperBlack350z's Avatar
SuperBlack350z
what kind of clutch do you have? i've noticed this problem with a lot of z's. Exactly how you explained it. To me, it seems like when the car is cold, the starter turns the motor which causes it to quickly have a scraping sound to it. It only happens on cold start ups. I don't think it's the throw out bearing even though i use to. Because once the clutch is already depressed, when you turn on the car, the motor start. I honestly think it's the flywheel. If your car has the usual flywheel chatter, then it will happen on cold start ups.
Old Sep 29, 2007 | 11:41 PM
SuperBlack350z
also, the pedal vibrations just seems to be input back to the pedal, which goes away also when warmed.
Old Sep 30, 2007 | 08:14 AM
failsafe306
The vibrations I'm experiencing don't go away after the car is warmed up. The squealing sound does go away after a few seconds of running though, but only after the car has been sitting overnight do I get any noise.
Question: is the TO bearing covered under warranty?
Old Sep 30, 2007 | 10:21 AM
SuperBlack350z
nope, unless it's a failing throw out bearing which yours is not. It's hard to get one as well if your car has teh stock throw out bearing from the manufacturer. I can see one failing if you installed one yourself and didn't grease it up well or didn't put the retaining clip on properly.
Old Sep 30, 2007 | 10:25 AM
failsafe306
It's the stock clutch on a JWT flywheel, that I installed myself last summer. New TO bearing was installed at the same time. It's been fine up until the last month or so. Then recently the squealing noise started on top of it all. BTW I don't drag race at all.
I made sure it was greased up and installed properly per the service manual. Weird. I guess all I can do is take up to Nissan and see what they say.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
