clutch line and fluid
hey everyone i just ordered a agency Power steel braided clutch line and motul rbf 600 fluid. is there a diy on how to replace the line and fluid? or what shop can install this? i live in simi valley california.
thanks rory
thanks rory
You asked if there's a DIY on this? Did you look to see? It's pretty easy. Main thing is, make sure you bleed the system good. Sometimes it's easier to pay someone for a peice of mind, if you never had done it. Just ask them if you can watch. Then you'll know next time.
it's really easy. If you know how to jack up your car(or have a lift), put it on jack stands, can located the clutch slave cylinder, it's pretty much straight forward from there. You will need another person pumping the clutch though.
