UR Pulley voltage drop
Old Oct 19, 2007 | 06:31 PM
led's Avatar
led
Default UR Pulley voltage drop
So, about a month ago I installed the UR Underdrive pulley. One thing that I noticed is that my battery voltage drops whenever I am stuck in stop and go traffic for a while and sometimes it drops so low that the Z shuts down. Today it sorta freaked me out because it the voltage dropped when I was getting off the freeway. The car died as I entered the off ramp and I almost went into a wall without my power steering.
Is there anything that I can do to keep the voltage from dropping and shutting down the car? Would a different battery help? Should I tighten the belts more? Would a grounding kit do anything?
Help me out fellas
Old Oct 19, 2007 | 06:36 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
its not the pulley. Its probably your alternator or battery.
I had the UR pulley, it only underdrives by 15%. You may see a volt or two less on the gauge, but that can be attributed to heat as well. I never had voltage issues, even with the low idle.
Ichigo's Avatar
Ichigo
Are you still running the original battery? Might be time to swap that out for a new gel cell
Old Oct 19, 2007 | 06:42 PM
led's Avatar
led
Yeah, I still have the original battery and I am at 45,000 miles. Hopefully that is the problem.
Can you recommend which one I should buy?
Old Oct 20, 2007 | 02:36 PM
led's Avatar
led
just wanted to let you guys know, it was a battery problem and it didn't have to do with the Pulley.
Thanks for the help
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
