So I cut the VDC wire...
Old Nov 1, 2007 | 10:25 AM
XuperXero's Avatar
XuperXero
There's no such thing as autozone here. I'm in Canada
Edit, just searched 15 pages... no VDC reset procedures... trying some other search strings now.
Old Nov 1, 2007 | 11:53 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
how did you reconnect the wire? you just cut one wire and reconnected it? solder ?
Old Nov 1, 2007 | 01:01 PM
XuperXero's Avatar
XuperXero
Twist on for now. Not soldering until I find out what exactly is the problem.
Old Nov 21, 2007 | 09:26 AM
KPierson's Avatar
KPierson
My Cipher allows me to reset VDC trouble codes. I didn't even know the VDC system stored trouble codes until I got the Cipher. If you know anyone with a Cipher have them take a look and see if a code is stored. Also, try unplugging the battery overnight - it may reset the code.
There are also other things that will cause the lights to stay on - like low brake fluid, bad wheel sensor, etc. It is very possible that you just ignored a 'new' problem because you thought the lights were indicating the 'cut wire' problem that you created.
Hindsights 20/20, but you would have been better off cutting the power wire to the VDC computer.
Old Nov 21, 2007 | 02:09 PM
daytona350z's Avatar
daytona350z
Originally Posted by Blu_Blur
Shoulda never cut it. Pressing a button is not that big of a deal. You probably do that all the time roll your windows down and lock the door.
You have to turn a key to make the car start, yeah?
Sorry. Just thought it was silly of you to do and hope everything works out for you.
disabling the yaw sensor does much more than just ''pushing the button''. im too lazy to explain or search the forum for you, but the gist is thas it also disable the "brake lsd" on a vdc equipped car.
Old Nov 26, 2007 | 10:53 AM
Blu_Blur's Avatar
Blu_Blur
^ too much of a hassle for what was originally desired IMO.
Old Nov 27, 2007 | 07:56 AM
daytona350z
Arrow
well, i guess it is, but if you did track your car you'd know how much a bother that sh*t is. theres probably a better way to do it anyways w/o frying something.
Old Nov 27, 2007 | 01:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
There is a better way to do this, if you search you'll find it... I'm too lazy to do it right now
aarrgghh
May 1, 2022 11:04 AM
sales@czp
Sep 23, 2019 03:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
