bro need help on ur crank pulley install
Old Nov 5, 2007 | 11:32 PM
j_z2006's Avatar
j_z2006
Default bro need help on ur crank pulley install
i just got a set of ur crank pulley standard recently, and the question is i have my engine remove out of the shell so i can see the pulley in front of me but what are the main point i need to take very careful to install it? or just unscrew it put it on and screw it back in. thx bro
Old Nov 6, 2007 | 12:12 AM
Quamen's Avatar
Quamen
Use a pulley puller to pull the crank pulley off.
Make sure that there is no burrs on the new crank pulley and/or crank shaft.
Install crank pulley without forcing it.
Easy
PS: you should use some grease
Old Nov 6, 2007 | 12:31 AM
j_z2006's Avatar
j_z2006
o shoot just found out thats not the oem size, thats for underdrive, whats the difference? should it come with a bolt? or just the pulley and belt?
Fixxxercask
Nov 9, 2015 11:10 AM
