Borla true dual is on; performance info.
Old Jun 6, 2003 | 11:08 PM
Alev's Avatar
Alev
I do believe this thread has been officially hijacked... That is until Steve comes back from the track.
Old Jun 6, 2003 | 11:11 PM
raceboy's Avatar
raceboy
Well, since there are obviously so many ways to state what I did, and you all understood exactly what I meant; my way is just as valid as any of the others mentioned.
Old Jun 7, 2003 | 02:59 AM
jreiter's Avatar
jreiter
Default Re: Re: Re: Borla true dual is on; performance info.
Originally posted by D'oh
That's funny, because I would have called it "repeatability" and "accuracy" instead (from an engineering/statistical standpoint).
But then, I only have a bachelor's...
Hehe,
D'oh!
No way man. It's "the same every time" and "right on". But then again, I ain't never even finished college...
Old Jun 7, 2003 | 06:16 AM
FLY BY Z's Avatar
FLY BY Z
Originally posted by webcarconnection
I have a Masters... but my thesis was that this system Kick ***!!!
Your thesis or your hypo-thesis or maybe it was a hyper-thesis.
Old Jun 7, 2003 | 02:02 PM
qirex's Avatar
qirex
Default Re: Re: Borla true dual is on; performance info.
Originally posted by rodH
interesting opinion on G-tech, that is called "reliability" when it is constantly accurate against itself, but may not be 100% correct (which is called "validity"), see I did learn something while working on my masters thesis
the .19 quater would be consistant with approx 20 HP, sounds GREAT
hmmm dont yuou mean Precision vs accuracy?
precision refers to the smallest variance recorded when reproducing a variable. Accuracy refers to the smallest variance between said variable and a "known" standard.
prolly semantics anyhow...
Old Jun 8, 2003 | 12:24 AM
D'oh's Avatar
D'oh
AHHHH, so many damn words!!
One of the benefits of becoming an engineer is that after a short time, you don't need to use them any more. Just focus on a couple of equations like F=ma and T=Ia and w= (k^1/2)/m
At this point, all I know is that I want this exhaust.
Thanks for the review, raceboy!
-D'oh!
Old Jun 8, 2003 | 11:47 AM
elektrik_juggernaut's Avatar
elektrik_juggernaut
Damn.....this thread sure went off on a tangent....all i wanted was a dyno sheet.
Raceboy, i noticed that on this exhaust there's no equalization tube, since it's a true dual. Do you hear decceleration popping in the exhaust when you let off the gas?
Old Jun 8, 2003 | 01:23 PM
TCL's Avatar
TCL
raceboy, that's good news about the exhaust fitting with thicker sway bars, and it sounds like you don't consider the number of clamps an issue. Qusetion, do you think the exhaust would have to be removed to replace the rear sway bar? This might help determine what order to do those two modifications for those considering both.
Also, how much louder would you say it is than the stock unit? Is it okay on long trips in your opinion?
Old Jun 8, 2003 | 01:44 PM
mdacko's Avatar
mdacko
quite the random thread. Anyway, who has the best price on one of these right now??
Old Jun 8, 2003 | 03:32 PM
all_bark's Avatar
all_bark
I ordered mine for $625 from Coz at performance Z.
Hopefully it will be here this coming friday as promised!
Old Jun 8, 2003 | 04:36 PM
zwindsor's Avatar
zwindsor
Twisty addict
There's a crossover pipe right after the cats so it's not a "true" dual system.
Old Jun 8, 2003 | 10:08 PM
D'oh's Avatar
D'oh
Just because it has an "H" pipe does not prevent the system from being "true" dual, right?
Practically every exhaust I've seen has some sort of arrangement of tubes to connect both sides of the exhaust in order to smooth out the sound.
Doesn't the new viper do the same thing since the original exhaust system sounded like a UPS truck with only the 5 cylinders exiting on each side?
What defines a dual exhaust anyway?
Thanks,
D'oh!
Old Jun 8, 2003 | 10:42 PM
hfm's Avatar
hfm
Thanks,
D'oh!
David Borla said the true dual Borla exhaust is true dual...if you drop ping pong ***** they will never touch each other. The two pipes never merge together, there are infact two separate pipes with no cross-over.
Old Jun 9, 2003 | 05:53 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I think originally the b/w installation graph shows there's a horizontal pipe between the two exhaust pipes right after the cat, but the finaly version does not have that pipe anymore.. it's a TRUE DUAL EXHAUST>.
Old Jun 9, 2003 | 08:06 AM
zwindsor's Avatar
zwindsor
Twisty addict
If you look at TXSTYLE's pics and this one below there is a crossover/connecting pipe about 6" long. It's not an "X" pattern so no ping ***** won't hit but gases will pass between the 2 sides.
I'm an oldy from way back when a dual exhaust meant a single line for each side and no connections what-so-ever. That to me is a true dual exhaust.
https://my350z.com/forum/showthread....threadid=32210
So when you say that the final version doesn't have this crossover then how many prototypes did they ship out because all the pics show the connection.
Just my $.02
Old Jun 9, 2003 | 12:02 PM
jreiter's Avatar
jreiter
Does it really matter if there is a cross-over pipe between the two sides? Would performance really suffer that much, if at all? I'm trying to get a grasp on the pros and cons of having such a connection.
From what I've gleaned off this discussion thus far:
1) A crossover pipe could smooth out the sound a bit.
2) A crossover pipe could potentially reduce performance (flow) if a signficant amount of exhaust gas was to travel through the crossover and cause a reduction of flow in the main pipes.
This sound about right?
Old Jun 9, 2003 | 12:44 PM
webcarconnection's Avatar
webcarconnection
Yes it has a H pipe rigth after the 1st connectors and before the resonetors.... but this give the right HP and sound!!!
Old Jun 9, 2003 | 12:58 PM
  #38
RODiculouZ's Avatar
RODiculouZ
Default Re: Borla true dual is on; performance info.
Originally posted by raceboy
It went .19 faster in in the quarter and gained 2mph. I did not see the 0-60 flash as I was concentrating too hard. I disconnected the groundwire before doing the baseline yesterday and I did it again today before putting in the new one. So that is the diffence between the old and new version Borla. I never posted numbers from the old version because they were identical to stock.
That's great to hear what you have found from the new Dual Borla exhaust. I have to ask though, when you said that it was 0.19 sec faster in the 1/4 and gained 2mph, is this an average from numerous tests(say 10 or more) or was this just from one run? I ask this because every launch and run on the 1/4 is never quite the same and it could have just been driver errors that could have given you the better times. I am not too familiar with G-force and how it works so forgive me if I sound like I am totally mistaking how it calculates things.
Regardless, its good to hear that you had some type of positive improvement. I agree that it should be dyno'd to tell us the true and accurate gains but just as long as you are satisfied with the exhaust, then it's all good. Have fun with it and drive hard!
Old Jun 9, 2003 | 01:10 PM
  #39
FLY BY Z's Avatar
FLY BY Z
An H pipe or an X pipe both allow equalization of pressure between two pipes. They sound different from each other but both provide better power gains over two separate pipes. The Borla is a true dual setup, it just has something that is technologically more advanced than the previous favorite setup. I mean, just because your an oldy doesn't mean you still use an abacus, does it?
An H pipe gives a more muscular sound and an X pipe gives a more exotic sound. Don't confuse these with a Y pipe which combines two into one. It is quite simple. Look at the respective letters and that is what the setup looks like.
Old Jun 9, 2003 | 01:40 PM
  #40
TCL's Avatar
TCL
webcarconnection, it was hard to tell from your videos how loud the exhaust is. How much louder would you say it is than the stock exhaust?
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Apr 28, 2017 09:00 PM
