Base model owners without VLSD, Have you changed your differential fluid?
Old Dec 12, 2007 | 08:23 AM
Diesel350's Avatar
Diesel350
Default Base model owners without VLSD, Have you changed your differential fluid?
If so what oil did you use (75w90 gl-5??) and did you feel any difference? At what mileage should it be changed?
Old Dec 12, 2007 | 08:51 AM
HondaKiller's Avatar
HondaKiller
i've been wondering the same thing. base model here with 54k never been changed. I was probably going to put stock back in it though.
Old Dec 12, 2007 | 09:37 AM
g356gear's Avatar
g356gear
If you do change it you will find lots of shavings and black sludge stuck to the magnetic plug. It usually takes 2 or 3 changes to get rid of all the metal in the differential. I would do the change ASAP. I did 3 changes in the first 5000 miles and it has stayed perfect ever since.Synthetic is great for cold climates. I didn't feel any difference in performance though.
Old Dec 12, 2007 | 09:53 AM
ofl0926's Avatar
ofl0926
i changed my to amsoil
tranny
https://www.amsoil.com/storefront/mtg.aspx
diff
https://www.amsoil.com/storefront/svg.aspx
Old Dec 12, 2007 | 02:24 PM
terrasmak's Avatar
Originally Posted by ofl0926
same here , but i have the vlsd in mine. the tranny oil change is noticable
Old Dec 12, 2007 | 02:27 PM
blackfairlady's Avatar
blackfairlady
Royal Purple 75w90 MaxGear GL5 in my Diff - Base model, as well.
Changed every 20k miles. (<--****. don't necessarily have to do it that often)
Old Dec 13, 2007 | 02:19 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
Motul Gear 300 for my diff...shifts a whole lot better
Old Dec 13, 2007 | 02:35 PM
Equinox's Avatar
Equinox
I'm not seeing how changing your diff oil will make your car shift better. Now changing your tranny oil out, I would expect better shifting with that.
OP: with an open diff, you're not going to see any difference or performance increase by changing out your diff oil. Just follow the recommended service guidelines for it.
Old Dec 13, 2007 | 09:12 PM
nismo240r's Avatar
nismo240r
x2. . .found a few shavings. . .kind of expected since i went to drift/auto-x all summer
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Tochigi_236
Sep 27, 2015 03:40 PM
