Is it possible to ADD cruise control?
In addtion to the difference in ECU, clutch and brake switches must be installed tapping into the wire harness. I believe this is why simply swapping ecu won't make c/c to work. What I'm also not sure about is whether enthusiast+ ecu is compatible with base models and what effect will this swapping ecu will have on rest of the car.
I really would like to try this on my base, but I don't want to void my warranty as my z only has 16k
Originally Posted by rocks
I just run one map, if i wanted more i would have to load it with the software.
Originally Posted by gsxrjohn
ALL Z's have cruise. You just need to know how to set it. I'll explain.
Press the accelerator to get you up to speed. Once your up to the speed you'd like to maintain, 60, 65, whatever. Note the position of the accelerator in relation to the floor and hold it there. If you lift it you will turn the cruise off.
Originally Posted by 05Z33
But how can you swicth from one map to another without the cruise control?
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
CFAUVEL
Oct 1, 2015 03:20 PM
