Is too much LSD oil bad?
Old Jan 23, 2008 | 11:50 AM
mavtais's Avatar
mavtais
Question Is too much LSD oil bad?
I just serviced my Nismo diff with the left-over Motul that I bought from Sharif@Forged 4000 miles ago (what a great vendor BTW!!!). The specs say that our diff holds 3 pints of oil, but I probably put in almost 4 pints (I pretty much finished one almost-full bottle which is ~2 Liters). Is too much LSD oil a bad thing? Obviously, too little is very bad.
Old Jan 23, 2008 | 11:53 AM
Motormouth's Avatar
Motormouth
won't it leak out the breather?
I thought you were basically supposed to fill it until it started leaking out of the fill-hole, and as long as the car is level you can't go wrong.
(correct me if wrong Kthnxsbye)
Old Jan 23, 2008 | 12:14 PM
gothchick's Avatar
gothchick
/\ That's correct.
Old Jan 23, 2008 | 12:35 PM
Motormouth's Avatar
Motormouth
if you jacked your car up from the back and it was leaning forward, I guess it is possible to overfill it a little, butI can't imagine a whole pint extra.
maybe the bottle had less than you thought in it?
Old Jan 23, 2008 | 12:39 PM
ke0ki2k's Avatar
ke0ki2k
how often do you change yours anyhow?
Old Jan 23, 2008 | 12:40 PM
jtabraham's Avatar
jtabraham
start with a level surface and keep filling until it dribbles out the fill hole.
Old Jan 23, 2008 | 12:43 PM
How do you put too much oil in the deferential? There is a hole in the side.
Old Jan 23, 2008 | 02:04 PM
Motormouth's Avatar
Motormouth
deferential? I don't bow to mine
also, with the Nismo LSD, I change it when I change my engine oil. 3k-4k miles.
Old Jan 23, 2008 | 02:45 PM
n1sm0r's Avatar
n1sm0r
I used to overfill my old welded diffs, and those were well over 15 years old and it was fine. Any excess pressure is released from the breather
Old Jan 23, 2008 | 06:46 PM
mavtais's Avatar
mavtais
Yeah, I had my car jacked up from the rear on the passenger side, so that makes the fill hole on the side higher. I'll see if there is anything I can do about opening up the fill plug and leveling it out.
This is the fifth time I changed my diff oil. I wait about 3-5K miles.
BTW, what is the "breather"?
Old Jan 24, 2008 | 05:40 AM
gothchick's Avatar
gothchick
It equalizes the inside diff pressure to the pressure outside of the diff.
Old Jan 24, 2008 | 06:04 AM
Motormouth's Avatar
Motormouth
it's on the top of the diff. you should see a line of fluid residue on the casing coming from the top (in the back)... just follow it up. I think it's just a hole with a valve.
Old Jan 24, 2008 | 11:39 PM
mavtais's Avatar
mavtais
Thanks Motormouth, I'll take a look.
So I guess the answer then is a unanimous "No, too much LSD oil is not bad."
Thanks, everyone!
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
