My Car Shakes On Idle? :(
Old Dec 29, 2007 | 09:44 AM
Zyclone Z's Avatar
Zyclone Z
Default My Car Shakes On Idle? :(
My car shakes on idle... The rpm guage goes up and down very slightly. Why does it do this ?
Old Dec 29, 2007 | 09:45 AM
DavesZ#3's Avatar
DavesZ#3
Rough, inconsistant idle.
Old Dec 29, 2007 | 09:49 AM
Zyclone Z's Avatar
Zyclone Z
Its very inconsistant. I noticed it right away because I turned my music down, and held onto the shift ****. I can hear her shaking... Should I just take her in and ask what seems to be the problem?
As far as Roughness, to me its rough because I just like to hear her calm...
The aftermarket parts I have on are just a plenum spacer and injen shortram.
Old Dec 29, 2007 | 09:50 AM
Jay'Z's Avatar
Jay'Z
Could be a leak in the plenum gasket causing the idle to fluctuate....
Easy way to check is.. Turn the car on, spray some intake/carb cleaner and ur car will tell uif u have a leak...
Old Dec 29, 2007 | 09:53 AM
SuperBlack350z's Avatar
SuperBlack350z
+1
Idle should be rough when the car is fully warm at idle if you do have a small leak. When the engine is cold, of course it won't be rough since the idle is at 1.5 rpm.
Old Dec 29, 2007 | 09:54 AM
MrWatchDawg's Avatar
MrWatchDawg
ya mine does that too ..it doesnt shake to say but the rpm keep going up or dow
i have a 05 roadster auto
-Mo
Jay'Z's Avatar
Jay'Z
Wow, im good.. And I didnt know ur mods...
Old Dec 29, 2007 | 09:57 AM
MrWatchDawg
i dont have any mods but a cold air nismo intake
-Mo
Old Dec 29, 2007 | 10:00 AM
Zyclone Z's Avatar
Zyclone Z
To tell ya the truth, I noticed it after I installed the injen shortram.
Old Dec 29, 2007 | 10:02 AM
MrWatchDawg
so i shouldnt take it in to the stealership than
-MO
Jay'Z's Avatar
Jay'Z
-Mo
Re check all ur fittings/ reset ur ecu bro... Have u done that???
Old Dec 29, 2007 | 10:06 AM
MrWatchDawg
i have had an intake on the car for about a month. but no i never reset my ecu?
stealership said they wanted $85 to reprogram it and i didnt wanna pay that much but i guess i need to?
-Mo
Old Dec 29, 2007 | 10:09 AM
SuperBlack350z
-Mo
You actually don't need to but it won't hurt. Driving the car for a month, it should be the same as resetting the ECU. Is your filter dirty?
Old Dec 29, 2007 | 10:19 AM
DraGonAlchemist's Avatar
DraGonAlchemist
one of 3 things is wrong. .your sucking in a small amount of air after the air mass. .you've damaged the air mass in some way COLD AIR intake. .perhaps by sucking it water. .and i get this all the time and even happ to me a while back with a customer's car. .when u installed the intake did you touch the throttle flap at all? say to clean any dirt?. .if your touch the throttle flap with out disconnecting the throttle body plug. .you'll throw off the settings and then you'll have to get it reprogrammed from the dealer. .
if you were sucking any air from the manifold/plenum. .you'd probably get a check engine light for bank1/2 rich or lean condition. .
check for AIR/VACUUM leaks all through the intake. .after the AIR MASS SENSOR. .cause b4 it doesn't matter. .air has to pass through it to be sensed. .perhaps you have a leak from the alittle hose MANIFOLD to the AIR intake!!
Old Dec 29, 2007 | 10:25 AM
MrWatchDawg
I got the intake installed at a shop but i was there watching him and it didnt look like he touched anything
and my check engine light did not come on at all so it can't be that
-Mo
Old Dec 29, 2007 | 11:34 AM
Zyclone Z's Avatar
Zyclone Z
I'm going to go get my oil changed right now.... I'll let you know if problem persists.
Old Dec 29, 2007 | 12:45 PM
singh's Avatar
singh
_______________
That rough idle is coming from that intake.
My brother has a AEM CAI intake on his RX8 and he has a rough idle also. It started happening after he installed the intake. The rest of his car is completely stock.
He took it out and washed it properly and it still has the problem.
pslamp32
Feb 8, 2017 09:07 AM
OdesiTT
Sep 30, 2015 10:47 AM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
