switching pumpkins
Old Dec 31, 2007 | 09:24 AM
GrayG35's Avatar
GrayG35
Default switching pumpkins
i currently have a 5at with the 3.3FD and i am switching out pumpkins with a 6mt to the 3.53 then soon swap that out with the 3.7FD. i remember seeing somewhere that i would lose my cruis controll. is that true? Also for those of you 5at's who did this swap how did you like it?
I tried searching already but came up with nothing but threads without the defenite answer.
thanks!
Old Dec 31, 2007 | 02:17 PM
Escobar's Avatar
Escobar
why would you lose cruise control?
Old Dec 31, 2007 | 02:25 PM
chefsz's Avatar
chefsz
Cruise is built into the Ecu I believe, there is nothing on the pumpkin that stimulates cruise
Old Dec 31, 2007 | 02:29 PM
Glex25's Avatar
Glex25
I know if you want to keep the LSD you better make sure the one that you are swapping with has it.
To add to the confusion I have my own question.
If your trading pumpkins lets say from a 6MT with VLSD to Auto VLSD pumpkin.
Does VDC have an effect?
Do both cars have to have VDC or would that be a mute point and would not matter?
Old Dec 31, 2007 | 04:05 PM
z2g's Avatar
z2g
You will lose CC with the 3.7 I believe. I went from the 3.3 to the 3.5 on my car and it makes a hella difference esp with FI
Old Dec 31, 2007 | 06:08 PM
terrasmak's Avatar
None , It reads wheel speed off the axles, and wheel speed off the front rotors. as long as the wheels are spinning in the proper ratio from front to rear and side to side you are fine. A gear ration change is not going to have any effect. Cruise control on the other hand, i cant say. It may work off RPM /speedo/wheel speed
Old Jan 1, 2008 | 11:06 AM
GrayG35's Avatar
GrayG35
so i will lose cruis controll with the 3.7 fd? anyone know why that is, or if theres any way around this?
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
