WTF?? sqeaky clutch
Old Jan 4, 2008 | 06:01 PM
sqashybus's Avatar
sqashybus
Default WTF?? sqeaky clutch
So i went to pizza hut to get some pizza and when i got home i turned off the Z and let go of the clutch. When i let it go it squeaked, so i was liike So pressed it again and on the release it squeaks. It wasn't doing that when i went to pizza hut and 30 min when i got home i starts sqeaking. Any1 know wtf this is?? car has 30k and is a 06 base
Old Jan 4, 2008 | 06:49 PM
BootieMAN's Avatar
BootieMAN
The spring behind the clutch pedal needs some WD-40 or your throw-bearing could be going out.
Old Jan 5, 2008 | 08:03 AM
sqashybus's Avatar
sqashybus
Where is this spring located? Can it be reached from inside the cabin or do i have to under the car?
Old Jan 5, 2008 | 11:23 PM
antennahead's Avatar
antennahead
Mine started doing that, it lasted a day then quit. It definitely sounded internal, like the spring the other poster stated. Had it not stopped, I would have tried to WD-40 it, as it is annoying.
John
Old Jan 9, 2008 | 01:59 PM
johzp's Avatar
johzp
Ok now i have this also...wtf? I will try finding out a solution or taking to my dealer
Old Jan 9, 2008 | 05:51 PM
BootieMAN's Avatar
BootieMAN
It's inside the cabin. If you look behind and above your clutch pedal you'll understand.
Old Jan 9, 2008 | 05:53 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
totally normal...wd it
Old Jan 9, 2008 | 06:19 PM
chefrey's Avatar
chefrey
you have a rubber clutch line and rubber makes squeeking noises when it stretches
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
