Transmission Fluid question
Old Jan 10, 2008 | 06:35 AM
dmroberson's Avatar
dmroberson
Default Transmission Fluid question
Ok, so I've read several threads on changing the transmission fluid. I've decided to go with Redline Oil, and all of the threads suggest mixing the MTL (70W80) and the MT-90 (75W90) oils together, to yield a weight closer to the 75W85 weight our transmissions use.
My question is this... is it really necessary to mix the two oils together? I'm asking because I figure that the MT-90 fluid, which is 75W90 should be good enough by itself.
Thanks.
Old Jan 10, 2008 | 06:50 AM
dmroberson's Avatar
dmroberson
NVM, I found the answer I was looking for...
Old Jan 10, 2008 | 07:55 AM
BabyZiLLa's Avatar
BabyZiLLa
How bout posting the answer so when people search this thread isn't a complete waste of time.
Old Jan 10, 2008 | 12:38 PM
RedBullRR's Avatar
RedBullRR
+1 on posting the answer.
Old Jan 11, 2008 | 07:02 AM
dmroberson's Avatar
dmroberson
Sorry, guys.
I called Redline. They stongly suggest mixing the MTL and the MT-90 together. It won't EXACTLY blend to the 75W85 that the transmission requires, but it's very close. They said that I can get away with using the MT-90 by itself, but it's better to be as close to the required weight, as possible.
That being said, I'm gonna blend the MTL and MT-90 oils together.
Old Mar 3, 2008 | 10:31 PM
LaoSiFu's Avatar
LaoSiFu
Sorry I don't have my manual anymore but how many quarts does our transmission take? Also did you mix 50/50?
~Robert
Old Mar 3, 2008 | 11:17 PM
350ZTheStandard's Avatar
350ZTheStandard
~Robert
3 1/8 qts I like Royal Purple straight 75 weight, meets or exceeds OEM standards, says so on the bottles. About $10.00 a qt.
Old Mar 4, 2008 | 06:01 AM
dmroberson's Avatar
dmroberson
about 3 1/8 qts, as mentioned. I haven't put it in yet, but I will be mixing it 50/50. Out of town on family emergency right now, so it's on my to-do list when I get home.
Old Mar 4, 2008 | 08:22 AM
LaoSiFu's Avatar
LaoSiFu
Thanks!!!
~Robert
Old Mar 4, 2008 | 11:21 AM
SpeedRcr's Avatar
SpeedRcr
Thanks.
ive ran royal purple, motul, and oem nissan fluid...the oem nissan is synthetic and held up just as well as motul...royal purple sucks
Old Mar 4, 2008 | 06:16 PM
Rowlett's Avatar
Rowlett
Why dose Royal Purple Suck?
I went to three diff. places looking for Redline oil, No one carrys it, Pep Boys- No, Orileys- No, Auto Zone- No!
Who has this on Stock, I have a day off tomarrow and i want to do it already... I really dont want to order it! --Help
Old Mar 4, 2008 | 06:50 PM
Rowlett's Avatar
Rowlett
AhhHaa!
Found it, Check Redline web site and do a search under the "Dealers" Section....Just an FYI
Old Mar 4, 2008 | 07:02 PM
dmroberson's Avatar
dmroberson
I considered Royal Purple, but after hearing everyone say it sucks, I chose Redline.
Originally Posted by Rowlett
AhhHaa!
I just ordered direct from Redline. Didn't mess with dealers...
Old Mar 4, 2008 | 08:22 PM
350ZTheStandard
Just don't let em tell you the world is flat, you might believe em again..
Old Mar 5, 2008 | 09:12 AM
dmroberson's Avatar
dmroberson
WHAT!! The world... ISN'T... flat?
j/k..
I couldn't find any concrete evidence that RP was bad, but assumed there was some truth to it, if several people said it.
Old Mar 5, 2008 | 08:09 PM
toy4two's Avatar
toy4two
amsoil reformulated their tranny fluid and you can run it straight in the 350z, no mixing.
http://www.amsoil.com/StoreFront/mtg.aspx
Performance Features
• Reduces friction, heat and wear
• Superior high temperature stability
• Resists heat, oxidation, acid build-up and varnish
• Lasts two times longer than conventional petroleum oils
• Improves cold weather shifting
Applications
Recommended for synchronized manual transmissions and transaxles that require 75W-85, 75W-90 or 80W-90 viscosities and any of the following performance specifications: API GL-4 and MT-1, ZF TE-ML 02B, 16A, 17A and 19A, Chrysler MS-9070, MAN 341 ML. Recommended for use in NV 4500 transmissions, and replaces GM part #12346190 and Chrysler part #4874459.
Meets GL-4 performance specifications required by some models of Acura, Hyundai, Infiniti, Kia, Land Rover, Lexus, Mazda, Mitsubishi, Nissan, Subaru, Suzuki, Toyota, Volkswagen, Hino Mitsubishi-Fuso, and Zetor. Ideal for muscle car transmissions such as Muncie, Borg Warner, Saginaw, Ford Toploader, Dearborn and New Process. Also recommended for Gear Vendors Gear Splitters.
Old Mar 6, 2008 | 04:17 AM
undrgnd's Avatar
undrgnd
One size fits all? They didn't reformulate it, the bottle still says 75W-90. You sound like an AMSOIL dealer.
Old Mar 6, 2008 | 04:38 AM
App6MT's Avatar
App6MT
Even if he is, there are plenty of people that speak highly of AMSOIL so it really doesn't make a difference.
Old Mar 6, 2008 | 11:31 PM
undrgnd's Avatar
undrgnd
You don't see any distinction between the honest feedback of an end user and the biased sales pitch of a vendor? Just trying to balance the equation dude, chill out.
Old Mar 22, 2008 | 10:26 PM
Midnight Ryderz's Avatar
Midnight Ryderz
Redline MT90 is the best you can run i dynoed my car and got 3.14 HP to the wheels using MT90 in the trans and 75-90 in the diff so i personaly like redline
