auto tranny fluid level
Old Jan 10, 2008 | 02:52 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default auto tranny fluid level
is there a place somewhere around the tranny i can check the tranny fluid level?
Old Jan 10, 2008 | 03:03 PM
SFMACGUY's Avatar
SFMACGUY
AT cars have a dipstick that's bolted down with a 6mm bolt (10mm head). You must remove the bolt in order to remove the dipstick. It's located between the firewall and intake plenum on the passenger's side (LHD cars).
Old Jan 10, 2008 | 03:13 PM
Ilov350ZEE's Avatar
Ilov350ZEE
where exactly the bolt located under or above?
will taking the bolt off void my warranty??
Old Jan 10, 2008 | 03:50 PM
Vader007's Avatar
Vader007
Looking at the picture you provided it should be behind the gold bracket bolted on to the back of your plenum where that greay connector is plugged in. Youll see it, its a tube with a cap bolted on the top to prevent anyone from servicing the tranny themselves.
Old Jan 10, 2008 | 03:59 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Old Jan 10, 2008 | 04:33 PM
DavesZ#3's Avatar
DavesZ#3
Read your owners manual, it has some pretty specific warning about the AT fluid. Basically it's sealed - leave it that way unless you have a really good reason to muck with it.
Old Jan 10, 2008 | 04:36 PM
Ilov350ZEE's Avatar
Ilov350ZEE
im not doing any servicing i just want to see the fluid level.
Old Jan 10, 2008 | 05:28 PM
dhwang80's Avatar
dhwang80
speaking of servicing, how often should one change it.
miles/years?
Old Jan 10, 2008 | 05:36 PM
Vader007's Avatar
Vader007
No you will not void your warranty, they have no way of knowing you did anything, besides checking you level would never void your warranty anyways.
Old Jan 10, 2008 | 06:55 PM
DavesZ#3's Avatar
DavesZ#3
miles/years?
Again, the Maintenance Manual that comes with your car states that it should be replaced every 24 mo / 30K miles.
Old Mar 9, 2008 | 02:58 PM
Ilov350ZEE's Avatar
Ilov350ZEE
im resurecting this thread. I checked my tranny fluid level this morning and it shows above than it should be. I know it should be between the grooves from there its about 2 1/2" above. Im not sure if it came out of the factory like that. Mine is 06 with 19,500 miles, should i get drain and refill or have nissan drain some?
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
