crank pulley vs pulley set
Old Jan 19, 2008 | 09:31 PM
J_Dizzle's Avatar
J_Dizzle
southcentral>me
Default crank pulley vs pulley set
is there any benefit to gettin the whole UR pulley set compared to just gettin the underdrive crank pulley?
is it just to keep everything matching under the hood or are all the pulleys lighter too?
Old Jan 20, 2008 | 12:11 AM
bbs350z's Avatar
bbs350z
the crank pulley is essentially the only one out of the set that actually frees up power. the rest do minimal gains. imo its not really worth the $300+top free up the +-5whp that you'll achieve with them
Old Jan 20, 2008 | 03:43 AM
undrgnd's Avatar
undrgnd
It depends on the brand. Some accessory pulleys are made overdrive to keep the respective components running properly because the associated crank pulley is underdrive. All are usually lighter, but if you get a standard diameter crank pulley, then the rest of the pulleys are just for looks imo. Get a high quality, steel insert, not underdrive, lighter crank pulley and call it a day.
Old Jan 20, 2008 | 05:47 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
The pulley "sets" look pretty, the crank is what nets you the improvement, and 90% of it is due to its substantially reduced weight vs the stock piece. Underdriving on these cars, with stock motors, does not net you any more substantial improvement vs stock diameter, so it's really your own call. For those who want a bit of extra shine in the engine bay, or do shows, etc, then the full sets do look pretty...but the accessory pullies won't do anything as far as power is concerned
Old Jan 20, 2008 | 06:25 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
thnx for helping!!.. I was actually doing a research on this... now I found my answer!
Old Jan 20, 2008 | 07:46 AM
J_Dizzle's Avatar
J_Dizzle
southcentral>me
thanks for all the help guys
Old Jan 30, 2008 | 01:20 PM
runnun's Avatar
runnun
anyone one here pro underdriven kit?
Old Jan 30, 2008 | 01:35 PM
Z1 Performance
Former Sponsor
tons of people do....its really whatever your preference is.
I have personally had an underdriven setup on my car for a long time, with a full stereo, and 0 issues whatsoever
Old Jan 30, 2008 | 01:47 PM
jonnylaw's Avatar
jonnylaw
Can a fluidyne/Ati (slightly overdrive) crank pulley work with ur lightweight acessory issues w/out issues?
Old Jan 30, 2008 | 01:51 PM
Z1 Performance
Former Sponsor
I have no idea
Old Jan 30, 2008 | 02:37 PM
Jeff92se's Avatar
Jeff92se
How does one get the alternator pulley off?
