drilling hole in throttle body
Old Jan 22, 2008 | 05:50 AM
gothchick's Avatar
gothchick
+1 on the TPS re-learn procedure.
Old Jan 22, 2008 | 05:56 AM
05Z33's Avatar
05Z33
Did it like 3 or 4 times already and still nothing changed. Maybe I'll give the JWT method a try. It will be cheaper than buying a new throttle body should I mess that up.
Old Jan 22, 2008 | 05:58 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by 05Z33
I stall out every now and then when coming up to a stop unless I roll into it slowly. My idle will drop below 600 and choke up a little before it climbs back up, and thats with the a/c on. With the a/c off forget about it I will stall. I have seen many Z's with the same problem. Yes I have everything secured tight and I've cleaned my MAF sensor.
Long tube intakes cause the VQ to stall. It happens on the G35s as well. Remove it and it will go away.
Old Jan 22, 2008 | 06:57 AM
App6MT's Avatar
App6MT
My Injen doesn't stall out my car.
Old Jan 22, 2008 | 07:09 AM
HondaKiller's Avatar
HondaKiller
neither does mine. The TB reset/relearn procedure did wonders for my stalling issues after the installation of the Spacer. I thought i got it to work 2-3 times but later found out the cycle didn't complete. If you ran the TB reset, when you started your car and reved the engine the Service Engine Soon light should have flickered back at you at certain points in the RPMs. If that didn't happen, then you didn't get it figured out.
+1 on having another problem. If you did get all your reset procedures to work, then you have another problem. Anything from a cracked hose to a leaky gasket. Improper installation of the spacer, something air related. All though my '03's idle is nothing close to steady, i dont stall. Good luck with things.
Old Jan 22, 2008 | 07:15 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
huh?
Old Jan 22, 2008 | 07:24 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no they don't
intake leaks or improper tuning/maf scaling (LTFT and STFT) cause the cars to stall
Old Jan 22, 2008 | 07:32 AM
Chebosto's Avatar
Chebosto
have you
1. removed all your air intake mods back to stock to see if the idle is still messed up?
2. checked for damage on MAF sensor/test voltage resistance
3. the throttle body is all software ecu controlled, so hardware changes will only make things worse. +1 on adam's comments. there is something fundamentally wrong with the car or the install of the mods.
Old Jan 22, 2008 | 08:39 AM
05Z33's Avatar
05Z33
When the unichip is removed it dosen't stall at all, but then I have to worry about leaning out. So whats worse occasional stalling or runing lean?
Old Jan 22, 2008 | 08:43 AM
Z1 Performance
Former Sponsor
well then you just answered your own question
you need to get it tuned...if it was tuned, it needs to be tuned again, with specific emphasis not only placed on wot (that's not the hard part) but overall driveability as well
Old Jan 22, 2008 | 04:41 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Some cars act differently. But it is a known fact that the long tube intakes have caused the Z and Gs to stall.
Remove the intake and put the stock one back in and I bet your stalling problem goes away. It's free to try.
Old Jan 22, 2008 | 04:43 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
No one was talking about tuning folks. We were discussing the problem at hand and what the cause is. And it is his long tube CAI. Without tuning they have shown to cause the VQ to stall.
Old Jan 22, 2008 | 04:52 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
For others to learn more about intakes causing the car to die.
http://g35driver.com/forums/showthre...+intakes+stall
http://g35driver.com/forums/showthread.php?t=66861
http://g35driver.com/forums/showthread.php?t=66719
http://g35driver.com/forums/showthread.php?t=66841
Turbulent air is the cause with a intake, and the MAF readings get screwed up then the car dies.
Old Jan 22, 2008 | 05:50 PM
05Z33's Avatar
05Z33
Unfortunatly I bought the car with the CAI, so I don't have the stock tube or filter box.
Old Jan 22, 2008 | 06:57 PM
Z1 Performance
Former Sponsor
I have a stock Z intake box for sale with filter....less than 1000 miles on it
Old Jan 22, 2008 | 07:48 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
The dealer can't do it unless I get an ECU reflash $$$ from them. The consult 2 only works for models before 2004.5. Trust me I have looked all around and I'm not looking to do an ECU upgrade again untill I go FI. Also I now JWT has a solution but it seems to be hit or miss with that.
wrong. the dealer can do it for any year OTHER than 04.5s. they can do 03 04 05 06 they usually charge one hour labor to raise it up. if you know someone with a cipher, it will work also.
Old Jan 23, 2008 | 07:35 AM
05Z33's Avatar
05Z33
Thats good to know, cause I was under the impression that the 05 could not be bumped. So if anyone down here in south Fla (MIA, FTL,) have a cipher and can help me out I'll through some cash your way.
Old Jan 23, 2008 | 08:30 AM
  #38
tourinz's Avatar
tourinz
Got a consult in delray....
Old Jan 23, 2008 | 10:25 AM
  #39
05Z33's Avatar
05Z33
So you have a consult and you can bump my idle? I have an 05 and I didn't think it could be done with a consult. PM me your price and we'll hook up.
Old Jan 23, 2008 | 09:58 PM
  #40
RA11325's Avatar
RA11325
Cool, can you tell where I need to drill the hole? Also do I have to take apart the throttle body once its off, and what size and type of drill bit did you use?
Just removed the throttle body and drill a 1/8" hole in it. Make sure you are pretty gentle because you dont want to bend the plate and try to avoid drilling it way on the outside. Once you are done just re-install your throttle body. I disconnected my battery over night to reset the throttle learning curve and ECU.
