Looking for A/F Guage. .any Suggestions?
Old Jan 28, 2008 | 09:15 AM
DraGonAlchemist's Avatar
DraGonAlchemist
Default Looking for A/F Guage. .any Suggestions?
i've looked around and searched but no 1 threads talks about what's a good guage to buy. .my buddy has an EVO and has the aem $300 guage that comes with an o2 sensor. .but i think i'd have to tap my exhaust to install it. .im not looking to do that, although he tells me that it's the best one out. .anyone have an idea?
Old Jan 28, 2008 | 09:28 AM
iStan's Avatar
iStan
ZR
You're looking for a AF gauge that doesn't tap into the TP/Cat/HFC/Exhaust??
Old Jan 28, 2008 | 09:37 AM
masterj26's Avatar
masterj26
INNOVATE
http://www.performancefactory.com/st...369d5533ca824e
AEM
http://www.performancefactory.com/st...0f4ddeecfdc016
You are going to have to tap into the test pipes. PM Black Guy (Performance Factory)on here and he can set you up with whatever you need
Old Jan 28, 2008 | 09:41 AM
DraGonAlchemist
yeah thats the AEM guage i was talking about. .and yeah i was trying to get the most accurate one with out tapping it into my exhaust. .if there is only the narrow band one's then i guess i'll just have to tap my exhaust. .thanx for those links. .
Old Jan 28, 2008 | 09:42 AM
iStan's Avatar
iStan
ZR
You have Narrow Band O2 sensors in your Z. You'll have to Tap. AEM and Innovate are popular.
Old Jan 28, 2008 | 09:52 AM
DraGonAlchemist
yeah i figured. .here is a thought that i was thinking about. .lets say i don't tap the exhaust.. but i use the existing hole for the new sensor and from that i splice the signal wire together with my OG sensor in order to get a reading for my ECU(of course i'd be powering it as well). .could that be doable?. .it's just a thought but it might work. .
Old Jan 28, 2008 | 09:55 AM
iStan's Avatar
iStan
ZR
Again, You do NOT have wideband Sensors, just narrowband.
masterj26's Avatar
masterj26
just get an exhaust shop to and a bung to your test pipes, doesn't cost much then you can install the wideband yourself
Old Jan 28, 2008 | 09:58 AM
DraGonAlchemist
i can bung it and all myself. .just didnt wanna have to tap into it is all. .ahhhh. .oh well ima have to bight the big one. .thanx!
Old Jan 28, 2008 | 01:00 PM
DraGonAlchemist
hmm. .i was just thinking on this topic as well. .say i get the AEM with the sensor. .it's only going to read out one side of my engine not both sides although 1 side should be significant, but on this topic im not sure. . .any info on that for me?
Old Jan 28, 2008 | 01:02 PM
iStan's Avatar
iStan
ZR
Most people run just one. I believe there is a small/negligible difference between the sides. Some will run the duals, it The Tech does.
Old Jan 28, 2008 | 01:46 PM
PM-Performance's Avatar
PM-Performance
PLX is another good wideband. I ran a few of them and worked great.
You can try replacing one of the stockers with the wideband all in all, but on a stock ECU it might get some hiccups.
Old Jan 28, 2008 | 01:49 PM
SuperBlack350z's Avatar
SuperBlack350z
you will have to install a bung or weld it in. I have a welded bung on my test pipe. If you want it to be accurate, you will have to do it this way.
Old Jan 28, 2008 | 05:32 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
always in stock
AEM: http://www.z1auto.com/prodmore.asp?m...mt&prodid=1760
Innovate offers a few types: check them out here:
http://www.z1auto.com/submodel.asp?m...cat=enginemgmt
we're offering 10% off all website pricing on Innovate right now as well
And lastly, we have a PLX M300 in stock we're letting go super cheap:
http://www.z1auto.com/prodmore.asp?m...mt&prodid=1554
Usually $349 shipped, will let it go for $310 shipped
Old Jan 29, 2008 | 04:12 AM
DraGonAlchemist
ohh man. .now thanks to HAL over at Z1. .. i now have 3 choices. .damn you!! haha. .so it's between the AEM~PLX~INNOVATIVE. . .which would you guys get??
Old Jan 29, 2008 | 04:33 AM
Z1 Performance
Former Sponsor
I'm Adam...no idea who HAL is
All are excellent units, at the end of the day it depends what you want it to do and where you want to mount it
If you want a straight forward gauge with no extra features, the AEM is awesome - far and away the most popular one we sell. The Innovate and PLX units are a bit more feature heavy for logging, etc.
Old Jan 29, 2008 | 04:49 AM
DraGonAlchemist
Question
sorry. .i got a PM that said HAL. .was all. .perhaps might of been someone diff, but no matter thank you as well Adam. . .now here's a ?. .the plx m300 says that it replaces your stock narrow band sensor. .does this mean that you remove the original sensor and plug in the plx sensor and it works both for ecu and the plx unit. .orrrr. .i see a section of more info but i cannot click on it. .so im a tad confused. .cause if im right and it does do what i think. .IM SOLD!!!! cause i really don't wanna tap n weld a bung into my exhaust. .unless i really have to! heh. .
Old Jan 29, 2008 | 04:52 AM
Z1 Performance
Former Sponsor
all the info is on our website:
I've never used it to replace the factory sensor on a Z, only on Evo/STi/WRX. Not sure how/if that would work on a Z since a Z has 4 sensors total due it it being a V series engine
Old Jan 29, 2008 | 05:01 AM
DraGonAlchemist
but it's capable of replacing the o2's on the car correct?. .well tell me this. .when you replace it on those other car's you've mentions say on an evo 4 example. .do you still plug in signal wire's for the ecu's readings for no CEL?. like is there a plug on the unit for the original o2 to be pluged into. .yes no. .or do you connect signal wires somehow. .how would you do it? .. . .
Old Jan 29, 2008 | 05:05 AM
Z1 Performance
Former Sponsor
As I said I have no idea if it is capable of doing it on a Z or not - I would tend to say no, since a Z has 4 sensors total, vs 2 for inline/flat engines our customers have used them on.
For any wideband on a Z, count on welding a bung in and running your own sensor- at least that's how I would do it, to prevent any signal degredation, potential ecu issues, etc.
