Here we go again!! (reflash question)
Old Feb 14, 2008 | 08:22 PM
ladyzed's Avatar
ladyzed
Default Here we go again!! (reflash question)
The search engine has blown a head gasket (I can't find the answer).
What makes a rev-up a rev-up? Not that I want one, it's just my upcoming 2004.5 VQ wants to be reflashed and I have the option to set the redline.
Is it safe to flash the redline to 7k? I know it probably won't make much more power after factory redline but I know it seems to cut-in too soon according to articles.
Oh, I've been thinking of using either UTEC, Alterted Atmosphere, or ... forgot the other brand.
Darryl
Old Feb 14, 2008 | 08:50 PM
pmohr's Avatar
pmohr
You mean vs a non revup model?
https://my350z.com/forum/showpost.ph...52&postcount=8
Originally Posted by Wired 24/7
Q: What is the difference between the REV-UP (300hp) and the NON-REVUP (287hp) Motor? Which one do I have?
A: Rev-up Motor has higher peak HP, lower peak torque, and a higher redline (7000RPM)
Non-rev-up Motor has lower peak HP, higher peak torque, and a lower redline (6600RPM)
Rev-Up Motor has variable Intake and Exhaust timing.
Non-Revup Motor ONLY has variable Intake timing.
You can tell which one you have by looking at your redline on your tachometer.
Old Feb 14, 2008 | 09:07 PM
ladyzed's Avatar
ladyzed
Sweet, thanks.
But, is it safe to reflash to 7k?
Old Feb 14, 2008 | 09:15 PM
pmohr's Avatar
pmohr
Sweet, thanks.
From what I've read, stock internals VQ35 is good up to ~7200 before many people start to worry about rod bolts. I know of a person that used to rev a stock VQ35 (FWD, nonrevup) to ~8k without problems...but not exactly recommended for a daily basis, if you get my drift.
I'd say go ahead and flash the higher limit.
Old Feb 14, 2008 | 09:24 PM
ladyzed's Avatar
ladyzed
I think 7k will be good then. I have to remember I'm not driving my 2007 Civic Si 6MT anymore (8100rpm). Gutless little wonder.
I won't be planning on major mods except:
plenum spacer
pop charger intake
Nismo exhaust (or Borla)
3.9 final ratio
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
