Auto Transmission not downshifting, giving codes P0442, P0456 and P1767.. Help
Old Feb 15, 2008 | 12:29 PM
soshiv's Avatar
soshiv
Default Auto Transmission not downshifting, giving codes P0442, P0456 and P1767.. Help
I was driving along today and all of a sudden my car started shifting extremely hard, then it stopped, then it shifted hard again and the check engine light came on... i came to a redlight and when i took off it was still in like 3rd gear!! next redlight same thing, it would not downshift from 3rd gear so i was taking off like a slow boat... when i arrived at my destination, i turned the car off and waited like 20 minutes then turned just the key on and the A/T light flashed about 5 times... I turned the car off again and returned the key and A/T light was not flashing, then i started the car and it seemed to be back to normal.... it was shifting through all gears again... i took it to autozone and they gave me codes P0442, P0456, and P1767... has anybody experienced this before?
Edit: I looked up the codes and P0442 and P0456 seem to be related to the fuel cap so i checked it and it was loose, i retightened and will try resetting the light once it stops pouring rain here... my main concern however is the tranny, this was strange that it would not downshift and i cannot find any mention of code P1767... the autozone paper describes P1767 as "High and Low reverse clutch solenoid valve" and wondering if it is serious enough to take to the dealer or try to fix it myself (if its even possible) car is a 2003 with 48,000 miles Automatic Transmission
Old Feb 15, 2008 | 03:37 PM
soshiv's Avatar
soshiv
anyone?
Old Feb 15, 2008 | 03:40 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
trans mostly likely dead.
Old Feb 15, 2008 | 03:46 PM
soshiv's Avatar
soshiv
if this is the case, isnt the trans warranted for 5yr/60K?
kennyl5123's Avatar
kennyl5123
check your trans fluid. if you find discolor or metal. your trans most likely dead.
Old Feb 15, 2008 | 04:16 PM
soshiv's Avatar
soshiv
cant check it right now since it is raining pretty hard... warranty manual says 60 months/60k miles on powertrain coverage... would my car fall under warranty since it is a 2003 with 48K?
Old Feb 15, 2008 | 04:20 PM
coachk's Avatar
coachk
P0442 and P0456 have to do with your EVAP control system. Could be anything from a loose gas cap to a leaking fuel vapor hoses.
Can't find the code P 1767....are you sure thats a right code.
Old Feb 15, 2008 | 04:24 PM
soshiv's Avatar
soshiv
yeah i read the code directly from the scanner that autozone uses, P1767... the Z service manual addresses this code on page AT-133
Old Feb 15, 2008 | 05:08 PM
coachk's Avatar
coachk
For future reference hit the search and put in ..codes??? and it should give you a thread with the whole list of codes.
Let me know if you found the thread
Old Feb 15, 2008 | 05:20 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Just curious... Are you FI? And if so, what turbo/SC, how much boost, whp, etc.???
Old Feb 15, 2008 | 05:24 PM
coachk's Avatar
coachk
soshi...I found the code P1767- High and Low reverse clutch solenoid valve.
Here's a better guide for codes..its in the maintenance & repair section under DTC Definitions thread. I think its a sticky
Hope that helps
Old Feb 15, 2008 | 06:38 PM
soshiv's Avatar
soshiv
rudeG - car is stock
Old Feb 15, 2008 | 06:44 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
OK. I was just wondering if boost/extra power was involved, because I'm going FI on my stock auto trans very soon. Thanks.
Old Feb 17, 2008 | 03:02 PM
soshiv's Avatar
soshiv
update: checked the fluid, its clean as a whistle, clean red color with no signs of metal after 3 dip checks... i also got to thinking, the P1767 code definition is "high and low reverse clutch solenoid valve" and since they are located on the valve body and nissan may try to rape me would i just be able to do the stillen valve body upgrade since dont they replace the solenoids and bore out the valves more?
Old Feb 17, 2008 | 04:29 PM
n2oZ's Avatar
n2oZ
Try going to dealer and having them change Tranny filter and tranny fluid. Then go drive it around for an hour, let it cool, then drive it a bit more.
I say take it to dealer because many people have problems after they incorrectly install a tranny filter ( ive seen em fall out becuase not properly seated, and even old bushing off the filter neck jammed up inside). Also gotta use nissans special fluid of course.
But you may just have one of those lil bearings gunked up and maybe a fluid and filter change can thin it back out.
burglapfd
Dec 6, 2020 01:04 PM
_bit
Oct 2, 2015 07:49 AM
