Best Performance Mods for N/A 5AT..
Old 03-05-2008, 05:24 AM
T_K
T_K's Avatar
Originally Posted by 2fast4ya
I read a previous post about types of exhaust and each one makes power
differently, for example i have y-pipe system with the oem style big canister
with the two tips(fujitsubo legalis-r) and it makes a lot of mid-range power
which i like for corner exits on road course, i have heard that true-dual
systems make power up top only and y-pipe single exits make power differently
as well
Layout doesn't matter. The only reason duals tend to give higher peak gains, is due to 2 60mm pipes or 2 70mm pipes being able to flow higher than a single 76.3mm(3inch) pipe. That doesn't really mean much, a well designed stock style exhaust layout, or a well designed single exit, can make just as much power as a dual and vice versa.
TK
Old 03-22-2008, 09:18 PM
03aeroZ
03aeroZ's Avatar
anyone know much about the a/t valve body upgrade for the tranny? any good ones and what does this cost to have done?
Old 03-23-2008, 07:43 AM
coachk
coachk's Avatar
Faster and harder shifts...a must for the 5AT. SGP and GTM have them and they cost between 800-1,000 dollars. Also check with Sharif from Forged Performance.
Old 03-23-2008, 12:07 PM
coachk
coachk's Avatar
For those of you with 5AT's go to the vid section and pull up "Daniels STS rear mount turbo" vid and you'll see an upgraded VB in action.
Sorry OP for going OT.....
Old 03-23-2008, 04:21 PM
03aeroZ
03aeroZ's Avatar
i have watched that vid, but what is really making the car shift faster...the turbo or the VB upgrade? I would think the VB upgrade is something you would notice driving the car more than listening to it drive by you. just my $0.02
Old 03-23-2008, 04:46 PM
coachk
coachk's Avatar
The turbo has nothing to do with the tranny shifting faster,that would be the VB that makes it shift faster. If you have ever been in a turboed car without a VB upgrade and then went in one with a VB upgrade then you would be able to watch the vid and say that guy has an upgraded VB...trust me
Old 03-23-2008, 05:04 PM
03aeroZ
03aeroZ's Avatar
ah..ok. I just assumed that since the turbo would make the car accelerate faster, then it would shift faster (faster climb in speed=faster shift was my justification, ill justified i guess).
so it makes shifts faster/more crisp. any other benefits?
Old 03-23-2008, 05:23 PM
coachk
coachk's Avatar
Faster and crisper shifts which will also keep the turbos in boost, as opposed to the 6MT that when you shift in boost the boost is reduced, unless you are Alberto of course
Old 03-23-2008, 05:32 PM
03aeroZ
03aeroZ's Avatar
what improvements in 0-60 or 1/4mile? thanks for all the info so far.
Murfdizzle21
Murfdizzle21's Avatar
maybe ill just mod the outside till i pay it off... then boost...
Old 03-23-2008, 05:33 PM
MardiGrasMax
MardiGrasMax's Avatar
Its noticalbe when you add a VB NA. Its much more noticable with boost. I had a stock VB in for my motor breakin and put the SGP VB back in on Friday. With the stock VB I would hit the revlimiter on the 2-3 shift, with the SGP it bangs quick much quicker and firmer! Highly recomanded!!!
Old 03-23-2008, 05:38 PM
coachk
coachk's Avatar
Keep the outside a sleeper(stock) and put your money in boost, its much more fun
Old 03-23-2008, 05:41 PM
coachk
coachk's Avatar
It was a long time ago when I put the VB and TC in,but IIRC it knocked 2-3 tenths off my 1/4 mile time.Most of that was from the TC
Old 03-24-2008, 03:26 PM
superchargedg
Damn Noobs
superchargedg's Avatar
I had the stillen stage4 for awile and when shifting i never hit the rev limiter but when i put on the greddy twins all i did was hit the limiter.I installed a forged performance vb and can shift quite fast enough now.
Old 03-25-2008, 08:58 AM
Azreen Khan
Azreen Khan's Avatar
How much is the VB Forge Performance? btw how many whp is your car?
Still shift good enuff?
Old 03-25-2008, 03:33 PM
superchargedg
Damn Noobs
Forged stopped doing them cause they had a big problem with one but it is essentially the same as sgp,s i think.Since i have the sh!tty borla with blown out cat convertor material in it all i got was 351rwhp and 392rwt on a auto on a dynodynamics.
My tuner said to get rid of the restrictive borla and put in a true dual and there is easily 40-50 more rwhp in it.
Old 12-17-2008, 08:47 AM
Murfdizzle21
bump
Old 12-17-2008, 11:43 AM
  #38
terrasmak's Avatar
Received 2,298 Likes on 1,655 Posts
Best mod?? 6mt !!!!
Old 12-17-2008, 08:19 PM
  #39
THe Emperor
THe Emperor's Avatar
^^^Wrong!
Old 12-25-2008, 10:19 AM
  #40
leg killa
leg killa's Avatar
what was NEXX talking about with the exhaust?im trying to go the same road..i buy lil upgrades here and there but still want to keep those mods for F/I minus the CAI that i got...he was talking about the exhaust thing
Quick Reply: Best Performance Mods for N/A 5AT..
