I NEED A So. Cal UR PULLER INSTALLER?????
Old Jun 24, 2003 | 07:00 PM
maserom's Avatar
maserom
Question I NEED A So. Cal UR PULLER INSTALLER?????
Anyone know of a good shop that you have experience with that could install a set of UR Pully's???? I'm located in Marina Del Rey, CA.
Old Jun 24, 2003 | 07:08 PM
importriders's Avatar
importriders
Ask SizongZ...he had a set installed. He lives in LA so I figure he got it done up there.
Old Jun 25, 2003 | 06:02 AM
xZlr8's Avatar
xZlr8
Default Re: I NEED A So. Cal UR PULLER INSTALLER?????
Um...you could install them yourself and save yourself a lot of money. If I were you I would just install the crank pulley and get your money back on the rest. Just my .02
Old Jun 25, 2003 | 06:53 AM
maserom's Avatar
maserom
I've heard on this board that the main pulley takes a special tool and is a real pain to get off. Why do you recommend not replacing the other 2?
Old Jun 25, 2003 | 08:27 AM
TheBigShow's Avatar
TheBigShow
a friend and i diy'd it. hardest part is the bolt holdin the stock crank pulley. u need someone on the foot brake and a strong sob to get the bolt off. breaker bar did the trick. the auto does sound a little more involved. u do need a thingy to hold the components on the other side of the crankshaft from spinnin. we just jacked it up and started takin stuff off. free install ownz joo!!!
Tochigi_236
Sep 27, 2015 03:40 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
