nismo finned diff. cover?
Mar 11, 2008 | 11:26 AM
any1 have this and how easy is it to install?
Mar 11, 2008 | 06:15 PM
Mar 11, 2008 | 08:30 PM
Quote:
yes and yes
Are you selling one?
~Robert
Mar 12, 2008 | 08:41 AM
Quote:
yes and yes
so im guessing "yes" its easy to install?
Mar 12, 2008 | 05:38 PM
Easy is a relative word. Its not "hard" but you have to drop the rear end.
Mar 13, 2008 | 06:31 AM
We had to also disconnect the rear exhaust and sway bar to drop the pumpkin far enough to install the diff cover. Not hard to do, just time consuming.
Make sure you torque everything back to spec so you don't lose an axle at 100mph - Lol
Mar 27, 2008 | 08:35 PM
I put mine on while doing a 3.3 rear end swap so it was very easy.
Mar 28, 2008 | 04:40 AM
Quote:
with the right tools, a vehicle lift, and a good mechanical sense then yes it is easy to do.
Mar 28, 2008 | 06:50 AM
I switched over to one when I had my 4.08 gears put in.
Jul 7, 2008 | 08:31 PM
Is there no way to do this with out dropping the rear end?
Jul 8, 2008 | 09:36 AM
^ Not gonna happen, there is no clearance.
Jul 8, 2008 | 10:13 AM
The pumpkin is actually bolted to the cross beam in addition to the chassis. Gotta drop it to get the cover off.
Jul 8, 2008 | 10:48 AM
how much should it cost to have this done in a shop?
Jul 14, 2008 | 04:20 AM
Quote:
Anybody ?
Jul 14, 2008 | 05:41 AM
(Probably) $85 bucks an hour times (probably) 3 hours.
Jul 14, 2008 | 09:18 AM
what type of gear oil should I use....oem, redline.......?
Jul 14, 2008 | 12:30 PM
Super Moderator MY350Z.COM
Jul 16, 2008 | 05:51 PM
Nov 17, 2008 | 05:16 AM
Does this diff cover add fluid capacity? if so how much fluid is needed to fill a NISMO LSD equipped diff with this Diff cover?
im gonna probably buy two, 2quart bottles of fluid just in case if no one knows??
anyone?
- J
Nov 17, 2008 | 06:14 AM
