pinion help
Old Mar 11, 2008 | 07:16 PM
umsracing's Avatar
umsracing
Default pinion help
Does anybody know if there is suppose to have any play on the pinion? I have about 0.0800 play. Is that normal? I tried sinching the pinion nut but no luck. I don't remember if it had that much play since I disassemble it 2 weeks ago.
Old Mar 12, 2008 | 12:28 AM
NISMO_558's Avatar
NISMO_558
you should have "0" or damn close to it. becasue 8/100ths is alot.
Old Mar 12, 2008 | 06:01 AM
umsracing's Avatar
umsracing
thats what i thought. thanks
Old Mar 12, 2008 | 09:43 AM
Eazzy's Avatar
Eazzy
You need what is called proper "Backlash".
Dont tighten down the pinion nut, you will overload the Brg by putting too much pressure on the Crush Sleeve.
The nut is there to load the brg and shims are used to set the backlash.
If its too tight it will howl....Fukcer gets HOT and expands !!!
Why are you concerned ? Is it making noise ?
Old Mar 12, 2008 | 11:20 AM
umsracing's Avatar
umsracing
No just putting it back together. I actually have it at a rearend shop right now. They are going to check it all.
Old Mar 12, 2008 | 11:42 AM
Eazzy's Avatar
Eazzy
Rearend set up is not for the DIYer if you want it perfect
bcoffee20
Nov 19, 2015 06:39 PM
ddegrande21
Sep 6, 2015 11:15 AM
bleunetizen
73
Apr 22, 2013 01:53 AM
SD350Z
Nov 20, 2006 06:08 PM
