Resetting the ECU data.
Old Jul 3, 2003 | 05:52 AM
Buub's Avatar
Buub
You're sure about that?
I've read that the ECU restricts performance somewhat during the break-in period. I would assume this means using slightly difference performance curves for the break-in. I mean if you're letting the seals set, getting the metal flakes out of the engine, etc., aren't you going to want to run the engine a little less "hot"? After all, you're told to not rev the engine over a certain RPM range (what was it, 2500?) until the break-in period is over, so obviously it's expected that the driver will drive the engine differently. Which doesn't make it all that unbelievable that the ECU would also run the engine differently.
Of course, I have no proof either way -- I just read about it from someone here, and nobody has provided proof either way.
Old Jul 3, 2003 | 12:21 PM
daking350's Avatar
daking350
Originally posted by chazzg
the easy to read Verson posted by Mannishboy a LOOOONG time ago... But i used it this moring and it works great.. (also a good trick for Racing)
[/B]
I tried this exactly but nothing happened...Maybee
I have the special ECU less model???
Old Jul 3, 2003 | 12:48 PM
chazzg's Avatar
chazzg
The Z Does Free up more Hp with more Miles(that has been Dyno tested and proven) But this will not Erase Everything from the ECM Just Some Data, like error Codes
The Timing is Very Important. It has to be right on, or it will not Work. It is best to use a watch or some other Time keeping Device. just Counting or Estimating will not work. I think it took me 5-7 times to get it right the First time
Old Jul 4, 2003 | 08:51 PM
MannishBoy's Avatar
MannishBoy
Wow, so many wives tales on the ECUs, and everybody acts like they are gospel.
Old Jul 4, 2003 | 10:32 PM
chazzg's Avatar
chazzg
well at least this is in the service manual
Old Jul 5, 2003 | 07:10 PM
zogan's Avatar
zogan
what about just unpluging the batery, wont that work?
Old Jul 5, 2003 | 09:15 PM
chazzg's Avatar
chazzg
I have heard that it will, but i have never Tried it.
Old Jul 6, 2003 | 01:48 AM
uklooney's Avatar
uklooney
You'll need to leave it unplugged for 24 hours, or so says the service manual.
Old Jul 6, 2003 | 08:47 AM
zogan's Avatar
zogan
24hrs, thats a lot, I have read that people have unlplugged it, then pushed their brake like 5-10times, then plugged the bat. back in. And their car run a lot better after they "reset their ECU". I didn't know it was for 24hrs?
Old Jul 6, 2003 | 10:10 AM
MannishBoy's Avatar
MannishBoy
He is correct. That is what the shop manual says, 24 hours.
Old Jul 12, 2003 | 04:18 PM
mcclaskz's Avatar
mcclaskz
I completed the series to reset, and my ces light blinked, 10 times slow, 10 fast, 10 fast, 10 fast, and then repeated. What the hell?
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
