100 octane tune NA
Old Mar 18, 2008 | 09:04 AM
jonnylaw's Avatar
jonnylaw
Default 100 octane tune NA
will a map tuned for 100 octane provide noticeable gains over 93 octane tune on a na care with bolt-ons? Or is it more for reducing knock?
Old Mar 18, 2008 | 10:07 AM
GrayG35's Avatar
GrayG35
i would think so
Old Mar 18, 2008 | 02:56 PM
ke0ki2k's Avatar
ke0ki2k
do it and see. ya running an interceptor/piggyback like Utec? no custom maps available from Cobb just yet, I doubt a reflash & tune for 100 oct will do much.
Old Mar 18, 2008 | 03:38 PM
jonnylaw's Avatar
jonnylaw
Shawn Church custom Osris maps
Old Mar 18, 2008 | 06:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Shawn can tune Osiris himself? I thought uprev had to do it
Old Mar 18, 2008 | 08:28 PM
jonnylaw's Avatar
jonnylaw
yes SC is licensed Osiris dealer and tuner.
Old Mar 19, 2008 | 03:31 PM
Frostydc4's Avatar
Frostydc4
I have a 100 oct map. At the track it makes a noticable difference.
Old Mar 22, 2008 | 07:36 AM
OCG35's Avatar
OCG35
yes SC tunes Osiris... I have a separate map for race gas (tuned with 105)... it dynos higher, but honestly it doesn’t seem much faster... I've only run once at the track with the new tune and race gas... "feels" similar to 91 performance tune... unfortunately I haven’t run back to back with 91 & 100+ octane so it's really hard to say.
The only reasonable way to tune with high octane is with Osiris so you can switch maps for the track and daily driving... if you are tuning one map only, it would be real expensive to always use high octane...
So when using Osiris, you might as well have one of the maps tuned on race gas - there’s no downside, even if the benefit is slim to none.
Old Mar 22, 2008 | 07:40 AM
OCG35's Avatar
OCG35
BTW - the tune won’t reduce knock... it more aggressive timing and if anything will cause knock if you don’t use high enough octane... so if you are tuned for 100+ you better make sure you are always using high octane (at least while in that map)... of course if you are tuned for 91 or 93 using higher octane won’t hurt (won’t help either though)...
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
