HUGE oil problem- 120psi.
Old Mar 18, 2008 | 09:25 PM
my-red-pony's Avatar
my-red-pony
Question HUGE oil problem- 120psi.
I cant figure it out - i called nissan, even brought it in and they said its fine, but it dosent make sense.
my oil press jumps to 120psi when i roll to full trottle, Ie: 3/4 trottle is around 80 psi.
wtf would cause this? bad oil pump? when i brought it in they just changed my oil and said my dipstick wasent in all the way- that wouldent cause 120psi that woulod drop it to 0 right?
I NEED HELP please.
Old Mar 18, 2008 | 09:27 PM
takissd's Avatar
takissd
are u sure its not a gauge problem? mine had the same issue at some time , went to the dealeship and changed it.... no problems after that
Old Mar 18, 2008 | 09:51 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Welcome to the forums.
This is covered in the top 100 questions thread. Click the link in my signature.
High oil pressure is not indicative of a problem. Low oil pressure might be, however.
As long as your oil pressure is not STUCK at 120psi, which usually indicates the detector is bad, then you should be fine. As Nissan says, it's fine.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
ablaine
Nov 29, 2016 10:13 AM
