Changing Oil: Crush Washer?
Old Mar 28, 2008 | 10:18 AM
Spork's Avatar
Spork
Default Changing Oil: Crush Washer?
I got three of these guys for future oil changes, and I'm changing mine today. I am a bit confused on which way it goes, etc. Could someone give me a quick answer?
Which way is supposed to be against the oil pan?
Old Mar 28, 2008 | 10:20 AM
Swiffer's Avatar
Swiffer
When I installed mine, I had the smaller opening towards the bolt, and the larger side facing the oil pan. It seemed to thread easier onto the bolt that way.
Also wanted to add that there have been no leaks yet.
Old Mar 28, 2008 | 10:23 AM
Spork's Avatar
Spork
Ahh, alright. So the top part in the picture would be against the oil pan? And the part that is resting on the table will be the side that the bolt is threading through?
Old Mar 28, 2008 | 11:31 AM
Swiffer's Avatar
Swiffer
Yep. That looks how mine was when I used it.
Old Mar 28, 2008 | 01:36 PM
krnzzang84's Avatar
krnzzang84
the flat side(top as shown in picture) against the moter, other part against filter!
Old Mar 28, 2008 | 01:52 PM
Z04's Avatar
Z04
huh?
Old Mar 28, 2008 | 01:58 PM
Z04's Avatar
Z04
just confirmed with the service manual and that is the right way. the top part in the picture is toward the oil pan
Old Mar 28, 2008 | 02:56 PM
Spork's Avatar
Spork
Alright. Thank you Z04.
Changed my oil and filter and everything's good to go.
I would've checked the service manual, but I can't find mine
Thanks again Z04.
Old Mar 28, 2008 | 04:21 PM
undrgnd's Avatar
undrgnd
Huh, what crush washer? Does anyone really use those? Four oil changes, factory washer, zero leaks. Mine has been crushed perfectly and just keeps on sealing, and sealing,...
Old Mar 28, 2008 | 04:42 PM
roast's Avatar
roast
when buying your filters you might as well stock up on the washers too... they probably aren't 100% required...but what's a few cents to do a job right?
I buy the filters and washers by the dozen...
Old Mar 28, 2008 | 05:11 PM
halfass872's Avatar
halfass872
Untill that one time it doesn't, and you have an oil leak. Then you'll wish you spent the 33 cents per washer and took the 15 extra seconds it takes to replace it!
Old Mar 28, 2008 | 07:08 PM
06dieselZ's Avatar
06dieselZ
whered you get these washers at???
Old Mar 28, 2008 | 08:10 PM
350ZTheStandard's Avatar
350ZTheStandard
Glad for the information, so far my Z has only had the oil changed at the dealership. Yes I know it is easy enough to do, & I do all the big maintenance and modding on my car, this is too cheap and the stealership also does a 27 point safety check when changing the oil. MY stealership will use the Royal Purple that I provide, they actually save me some cash beacuse I provide the oil, but they still get ne for the oil disposal charge.
Old Mar 28, 2008 | 08:26 PM
Swiffer's Avatar
Swiffer
Dealership. They are under a buck a piece.
Old Mar 29, 2008 | 08:12 AM
singh's Avatar
singh
_______________
I have never used it on my brothers RX8. I also haven't used it on my dad's Tundra or my mom's Sequoia. They are all well above 70,000 miles with zero leaks, zero problems. But whatever gives you piece of mind.
Old Mar 29, 2008 | 08:33 AM
taurran's Avatar
taurran
I just use the cheap metal ones with rubber coating from discount auto. They work great.
Old Mar 29, 2008 | 11:49 AM
Spork's Avatar
Spork
I know they're not necessarily needed, but 3 for like $1.27 why not?
Old Mar 29, 2008 | 07:20 PM
seekndestroy19's Avatar
seekndestroy19
it only takes 5 seconds to change so might as well.
Old Mar 30, 2008 | 06:36 AM
blastoff99's Avatar
blastoff99
Question about this, roast. Unless you are changing your oil and filter really often, why buy filters in quantity? I realize you probably get a small "case discount," but it can't amount to much. My theory is to get the newest filter possible, and if I've got three years' worth hanging around in my closet (or worse yet, my garage), they're just going to be picking up moisture from the air, and perhaps compromising the effectiveness of the element.
Your thoughts?
(to the OP: thanks for the question, and sorry for the hijack.)
Old Mar 30, 2008 | 06:38 AM
halfass872's Avatar
halfass872
Your thoughts?
I too have wondered the same thing!
