Installed 3.9 FD and worse acceleration
I have just installed the 3.9 FD on my revup, and tested it with a friends nonrevup Z, and now I have worse acceleration than before. Now all the advantage that I take on him thanks to the shorter gearing, I loose it in the moment that I change sooner than him.
All the Z that have installed the 3.9 FD in Spain have the same problem...is that normal aswell there in the States???
Cranky FI Owner
Its your shifting. You are losing more ground because you are shifting more often and you arent good at it. If you could learn to NOT lose momentum during shifts, you would be faster at all mph and rpm's and wouldnt fall back at those spots.
I am not being mean, just honest, I know EVERYBODY can drive like pro's online....
edit-before anybody steps in and tries to say "driving from a roll isnt a big factor", its HUGE, as can be seen below.
http://www.youtube.com/watch?v=-gafwal26KU
Well, if I left on a side the fact than if I shift fast or slow, what my post was triying to mean is that, before the install of the 3.9 FD my car accelerated the same than my friend's, and now it's like his one is faster. Both drivers are the same, so the conditions are also the same, just my 3.9 FD.
and what we are saying is that you only think his car is now 'faster' because when you shift (slowly we assume) that he gains ground on you. it is not because your car lost power persay.
do a single gear run, like in 3rd, where you don't shift, and you should accelerate faster.
Originally Posted by Alberto
No 2 drivers are the same. You may have been equal in the races before, you are now slower for reasons I stated above.
Denial is the 1st step in realizing you may suck ***** at racing...we've all been through it.
I start pulling a little over him in a gear, but I have to shift sooner than him, and then he caughts me again, next gear again and again
on
Originally Posted by raditz
Yea, Alberto, I know that 2 drivers are never the same, what I mind is that I am the same as before and he also just one thing changed from the equation, the gearing.
When I switched out my gears it was a night and day difference.
Do you think that the problem could be the top speed that you loose in every gear? increased redline will improve top speed...
just practice being faster and you'll beat him every time.
Yes, I have a little little more acceleration than before, but I also loose top speed in every gear, what means that I have to change sooner, lefting my car in a higher gear than him, and with less acceleration until the moment he changes to the same gear than me.
but seriously, as alberto and others said, just practice practice practice. when I shift slow, my friend in his evo would pull a fender, then next gear a car... and when I quickshift (no special technique, just moving faster) we stay even... that is a car I don't lose on him just from shifting technique. I wish I had pictures.
actually, check out Alberto's vids with him and EagleTan's car for a perfect example of this.
Originally Posted by Gooey
theres your problem...I know its hard to take in sometimes to admit your own mistakes and flaws but you have to do it sometimes.
Of course I can improve my aceleration shifting faster, that will happen using a short or hi gearing, but the problem is that I wasn't expecting to loose aceleration after the install of the FD, being equal in shifting.
lol, if you are looking for reasons to mod your car sure hahaha.
Cranky FI Owner
Now that you shift sooner, your friend is still in powerband while you shift and the fall back is more noticable. He then shifts and you may stop his pull or pull back slightly, but then you shift and lose what you just gained.
ITS YOUR SHIFTING
Did you watch the video? I have a 3.3FD and he has a 3.5FD, notice even though I run a FD that technically makes me slower, I outrun him, and when we switch cars we are dead even....its you man, just go practice!
