04 Tranny
Hey guys. I am new to the board so i'm prepared for crucifixion if I already missed this question somewhere, but I was wondering if the 04 tranny replacement was limited to a certain production date frame? if not, is this a recall that Nissan is responsible for even if i am over warranty? Thanks in advance.
Originally Posted by 04touring
Am I correct in assuming this would be covered in the powertrain warranty that is up to 5yr/65k miles instead of the 3yr/36k miles bumper-to-bumper?
--Spike
___________________________________
EDIT (some additional info)
- Your dealer will likely need to order the new transmission. That takes a week or two.
- Installing the transmission takes 3 or 4 hours. That means it should be a same day task, so you can drop-off and pick-up the car on the same day. The dealer does not need to keep the car overnight so you are not without the car for more than a day.
- Since this is a warranty repair, there is almost no margin for the dealer. The dealer may suggest a clutch replacement. Don’t fall for this ploy unless you really do need a new clutch. If you decide doing a new clutch, it should be very inexpensive when done at the same time as a transmission replacement since there is hardly any additional labor expense under this scenario.
- You will really like the new transmission. It is much better than your original.
- Your new tranny may have a “whine” sound. Don’t be concerned about this since it is not indicative of any problem. The whine decreases and pretty much disappears after driving 5k miles on the new transmission.
etkms
Jun 19, 2022 06:30 PM
seagrasser
Oct 11, 2015 03:27 PM
