I'm overheating BAD!!!
Old Apr 18, 2008 | 02:15 PM
slidewayz's Avatar
slidewayz
Unhappy I'm overheating BAD!!!
Here's a quick run down.... I have a 04 350Z with a Turbonetics single turbo kit on it. I have narrowed my issue down to the four newest parts I've put on it. A JVT 3 core radiator with a 1.3 pressure cap and a aftermarket thin fan, a Nismo thermostat, and a water cooling kit from Turbonetics for the T60-1 turbo (This kit splices in the water lines going into the back firewall and runs the water through the turbo, out, and back into the 2nd water line on the firewall..the one that comes back out and back to the cooling system.) I put all four of these parts on at one time and that's when the cooling issue really started.
PLEASE, ANYONE WHO MIGHT HAVE AN IDEA, HELP ME OUT!
Old Apr 18, 2008 | 02:20 PM
j.arnaldo's Avatar
j.arnaldo
Go to a radiator repair/sales shop, & explain your problem to a technician there; he may have a diagnosis/solution to your predicament. The stealer-ship should be your LAST option 'cause of their $$$-hunger! Good luck.
Old Apr 18, 2008 | 02:23 PM
ColecatZ's Avatar
ColecatZ
My first guess is that somewhere, one of your additions isn't holding pressure so your thermosat isn't opening.
but where that might be is impossible to determine from my seat... I'd first check to make sure all connections are solid.
edited for type-o's
Old Apr 18, 2008 | 02:24 PM
coachk's Avatar
coachk
Shoot taurran a PM..he is the Turbonetics go to guy He's usually always in the FI forum so he probably won't see your post here.
Old Apr 18, 2008 | 02:42 PM
superchargedg's Avatar
superchargedg
Damn Noobs
How did you bleed the coolant system after those mods cause it sounds like you have a big air pocket in the system.
Old Apr 18, 2008 | 02:51 PM
slidewayz's Avatar
slidewayz
I drove the car a little bit and then topped off the coolant 2 times.
Old Apr 18, 2008 | 02:53 PM
slidewayz's Avatar
slidewayz
Thanks
Old Apr 18, 2008 | 02:55 PM
Jay'Z's Avatar
Jay'Z
You didnt bleed it properly.. same happend to me....
Old Apr 18, 2008 | 02:59 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
^+1
iStan's Avatar
iStan
ZR
Look for coolant bleeder in the rear of the engine bay, passenger side. It's a plastic screw. Open until coolant flows out. Rinse and repeat.
Old Apr 18, 2008 | 03:00 PM
Drewer's Avatar
Drewer
Probably air in coolant system. . .bleed it.
Search in the FI forum for Evans NGP+ and all the different Radiator threads. . .and if you want a long read, check this thread out:
https://my350z.com/forum/showthread....352269&page=19
edit: meh. . .I'm too slow.
Old Apr 18, 2008 | 03:02 PM
superchargedg
Damn Noobs
Might have to do this many times.
Old Apr 18, 2008 | 03:06 PM
SpeedRcr's Avatar
SpeedRcr
if you didnt bleed it right it will overheat else your thermostat is failing
Old Apr 18, 2008 | 03:24 PM
slidewayz's Avatar
slidewayz
I was worried that running the turbo into the cooling might have been too much....or the fan isn't big enough and isn't pulling enough (Maybe a combination or the two). I won't get a chance to start work on it untill Sat. night, so it's going to drive me crazy untill then.
Old Apr 18, 2008 | 03:50 PM
slidewayz's Avatar
slidewayz
Does anyone have a pic of this bleeder valve?
Old Apr 18, 2008 | 11:10 PM
iStan's Avatar
iStan
ZR
Per Rookie
http://img.photobucket.com/albums/v3...elief_plug.jpg
Old Apr 19, 2008 | 07:28 AM
maximumsportZ's Avatar
maximumsportZ
Turn your heat on full blast, does it blow like if your A/C is on cold? Most likely air in the system. PURGE it.
Old Apr 20, 2008 | 09:34 PM
slidewayz's Avatar
slidewayz
Thought I would give you guys an update. I got all the air out of the system and I haven't had a problem yet.
Thanks everybody for the help!!!!
Old Apr 21, 2008 | 05:45 AM
gothchick's Avatar
gothchick
For those that may still be wondering.
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
