Anyone else use BG 44k?
Old Apr 29, 2008 | 06:00 PM
Nexx's Avatar
Nexx
Default Anyone else use BG 44k?
I put this stuff in my 87 deuce and its probably in my head but the car seems to run smoother with a bit more pep. Tail pipes have carbon build up for the first time after I used this stuff. Just wondering if anyone of you guys have had any experience with this stuff before. So far so good for me.
Old Apr 29, 2008 | 06:02 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
i used to use it at the dealership but it worked really well actual proven results, i still use the MOA on some of my oil changes.
Old Apr 29, 2008 | 06:10 PM
UMW350Z's Avatar
UMW350Z
BG is top notch stuff...all of it, used to sell it at my old shop. Their stuff gets results, especially the engine flush (run it 10 minutes before you do the oil change as indicated). It literally brought cars back from the dead....trucks blowing smoke, cars that barely run....that stuff works miracles. Cars that didn't pass emissions, we recommended doing that and bringing it back the next day....90% passed after just doing that. And no, we didn't cook the numbers...the service is only like 20 bucks plus oil change, not a moneymaking scheme.
I dumped the 44k in the Z at about 25k on the clock...MPG seemed to go up slightly...but nothing truely noticeable. it was pretty clean to start with...
Old Apr 30, 2008 | 04:39 AM
superchargedg's Avatar
superchargedg
Damn Noobs
BG products are top notch and most of your dealers and good shops use the stuff.
Old Apr 30, 2008 | 10:44 AM
SpeedRcr's Avatar
SpeedRcr
i use it once an oil change
Old Apr 30, 2008 | 02:51 PM
OCG35's Avatar
OCG35
I haven’t used it but did a bunch of research on it and read all great things... It’s a PITA to find tough! I finally gave up.
I've also read that it is better to do the pro-kit direct through the injectors rather than the can in the fuel tank... but I couldn’t even find the stuff to put in the tank
powashiftin
Jan 15, 2013 08:49 PM
meterp88
Mid-Atlantic Marketplace
Sep 16, 2012 07:25 PM
nhan2
Feb 22, 2012 10:45 PM
