How to flush clutch hydraulic fluid?
Old Apr 30, 2008 | 02:17 PM
cyc5181's Avatar
cyc5181
Default How to flush clutch hydraulic fluid?
Hi guys,
Well, to make the story short, i'm trying to flush the hydraulic fluid for the clutch so that when my clutch sticks again, I can take it to the dealership and have them replace my master cylinder. My car has only 27000 miles on it, so needless to say, I was pretty pissed at the dealership (Sterling McCall Nissan in Houston).
Can someone show me where I can get some step-by-step instructions on how to flush the fluid? I've searched this forum, maybe I'm using wrong words, but I can't find what I need.
I think it would be nice to have these "how-to" threads become "sticky" threads, or have a DIY section for them. just my .02.
thanks guys,
Andy
Old Apr 30, 2008 | 02:39 PM
HDPDZO6's Avatar
HDPDZO6
If it's anything like the vettes, then it's easy.
Go buy 2 cans of the respective fluid, a funnel, and syringe.
With the motor off...
Remove a syringe full of used fluid
Add a syringe of new fluid
Pump the clutch ~20 times
Repeat the above steps until the fluid is clean.
Old Apr 30, 2008 | 03:29 PM
terrasmak's Avatar
You bleed it just like you do on brakes. There is a bleed port on the clutch slave.
Old May 10, 2008 | 11:05 AM
yellowlady's Avatar
yellowlady
i want to replace the clutch line with a SS line and the fluid. i need instructions. please instruct or point me in the direction of a thread that does.
i am terrible at finding things via the search, but i try and try.
Old May 13, 2008 | 04:54 PM
yellowlady's Avatar
yellowlady
could someone please point me in the right direction on this?
Old May 13, 2008 | 05:03 PM
djtimodj's Avatar
djtimodj
on the left hand side of the gearbox in the tranny tunnel the bleed nipple is on the slave cylinder, just bleed it as you would the brakes.
Old May 16, 2008 | 06:23 PM
CSF's Avatar
CSF
i'm trying to find this too...i'll keep searching but if anybody knows off hand, i'd appreciate it
Old May 17, 2008 | 08:17 AM
CSF's Avatar
CSF
after searching everywhere...here's what i found:
It's pretty simple. Jack up the car and put it on stands. Then, climb underneath and find the clutch hose. Put a clamp on the rubber hose to stop leakage from when you take the bottom fitting off. Disconnect the bottom end of the hose from the slave cylinder and then connect the bottom of the new hose to the slave cylinder. Now, take the top of the old hose off and quickly attach the new hose. Try not to be messy. Bleed the clutch and top off the resevoir with genuine Nissan brake fluid.
Make sure you use a 10mm line wrench. The metal on the fitting is extremely soft and an open end 10mm will destroy the fitting. Trust me.
simple enough
Old May 17, 2008 | 08:50 AM
350 Rookie's Avatar
350 Rookie
heres my dyi
http://hlcreationz.proboards52.com/i...lay&thread=321
Old Jun 21, 2008 | 12:31 AM
SoldzMyZ's Avatar
SoldzMyZ
Bump does anyone one know how often you have to do this for maintenance?
Old Jun 21, 2008 | 04:08 AM
Barzten1's Avatar
Barzten1
Originally Posted by cyc5181
Hi guys,
thanks guys,
Andy
What symptoms are you having? Im having clutch issues too but my clutch had 2500 miles on it. Sometime it shifts like I have a brand new tranny and sometimes it wont go into gear at all and for the most part its grindy. Thiss happened all of a sudden about 300 miles ago
Old Jun 21, 2008 | 07:15 AM
CSF's Avatar
CSF
that doesn't sound like something that changing clutch line and fluid would fix. is it all gears? maybe a synchro problem?
Old Jun 21, 2008 | 04:07 PM
Barzten1's Avatar
Barzten1
Originally Posted by 350 Rookie
Very useful. Thanks
Old Jun 21, 2008 | 06:17 PM
Eazzy's Avatar
Eazzy
Seldomly, if ever. If you choose to, just open the bleeder and let it gravity bleed while replenishing fluid. Close bleed after a half bottle of fluid and your good to go.
As far as the SS Line install. break the 10mm fitting loose where your flex line goes into the solid line....Just loose, and tighten it again with your fingers. Pull off the retainer. Next, break the banjo fitting loose at the Slave. Re tighten with your fingers.
Have everything layed out. Have some one to replenish fluid.
Quick as a bunny on speed, unscrew the upper fitting and screw in the new SS line. Next, unscrew the banjo bolt and screw in the SS banjo. Tighten it. Tighten the upper connection, install the retainer.
All this time the resivour NEVER runs dry because you have someone that is constantly adding fluid.
Open the bleeder and tap the slave/lines to knock the bubbles loose. Tighten it and pump your clutch. Best to start the motor because the vibration helps break loose air. Repeat -Repeat.
lapham3
Oct 7, 2022 03:15 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
SharX59
Sep 27, 2015 09:23 AM
