LC 1 qestion
Old May 5, 2008 | 03:15 PM
05Z33's Avatar
05Z33
Default LC 1 qestion
I just installed my LC1 wideband. I have everything connected except the O2 sensor, because I'll be getting the bung welded in tomorrow. I have the sensor conneted to the LC1 but not the pipe. Will this damage the sensor, or should I remove it from the LC1?
Old May 5, 2008 | 04:17 PM
pmohr's Avatar
pmohr
I wouldn't power it up outside of the exhaust, personally (short of calibration, anyway).
Old May 5, 2008 | 06:04 PM
05Z33's Avatar
05Z33
So will I be ok if I just unplug the sensor from the LC-1, or do I need to disconnect the power supply to the whole system?
Old May 5, 2008 | 08:48 PM
JonnyC's Avatar
JonnyC
Just unplug the sensor from the LC-1...at least that's what i've been doing
Old May 7, 2008 | 02:41 PM
mowgli29's Avatar
mowgli29
I know this was a couple days ago, but just so everyone knows....The manual says to NEVER have the sensor in the exhaust without it powered up. If you've got the sensor in the exhaust, it better be connected to the LC-1 and powered up before you drive. The sensor can be easily damaged otherwise...
On the contrary, it says nothing about powering the sensor and leaving it in free air.
Old May 8, 2008 | 10:05 AM
BrazenZ's Avatar
BrazenZ
Yes, you can power up the sensor if the module and all the cables are connected, but be warned that sensor end gets hotter that a *****.
Old May 8, 2008 | 10:12 AM
mowgli29's Avatar
mowgli29
Originally Posted by BrazenZ
I have the LCM-1 module that I use to tune my carburated 79' Vette. I usually install the sensor in the exhaust bung being carefully not to touch the sensor end. Then I hook the cables and power up everything. I can't imagine why you would need to twist the cable and the module togather while making up the sensor to the bung.
is that in response to what I said? I'm not quite sure I follow what you're saying...
Saudi
Jun 5, 2010 06:15 PM
worldchamp
May 29, 2009 07:42 PM
BoostedProbe
Mar 16, 2009 05:32 AM
Dblock55
Feb 10, 2009 05:17 PM
