Lighter flywheel question
Old May 6, 2008 | 06:53 PM
chaparro78's Avatar
chaparro78
Default Lighter flywheel question
Is there a lighter flywheel that won't make the rattle that the JWT flywheel makes? Or is that something you just have to live with? (Yes, did search, couldnt find anwers i wanted)
Old May 6, 2008 | 11:23 PM
gsazabi's Avatar
gsazabi
What clutch/flywheel combo are you running right now? If I remember correctly Exedy flywheel emits less chatter.
Old May 7, 2008 | 10:33 AM
SteveZ's Avatar
SteveZ
last vortech SC I heard made more noise than I have "chatter" noise - I never hear it unless I have the window down, stopped in neutral with the clutch out - and it's pretty hard to hear at that.
Old May 7, 2008 | 11:00 AM
chaparro78's Avatar
chaparro78
Still stock, but upgrading soon. It has over 70k miles on it and 60k with a S/C
Old May 8, 2008 | 04:51 AM
jmccartney's Avatar
jmccartney
get the competition stage 2 clutch and there street flywheel. the flywheel only weighs 11lbs. No chatter or b.s.
Old May 8, 2008 | 05:17 AM
chamois's Avatar
chamois
I had a JWT clutch and flywheel and it had no rattle at all. the honest thing with lightweight flywheels and clutchs is that most all of them have tendency to rattel becuase your getting rid of a lot of weight and so there is less mass in the flywheel to absorb the noises of the tranny. its not bad though, just do some searching. find whats best for your application
Old May 8, 2008 | 06:05 AM
SteveZ's Avatar
SteveZ
I'm noticing a trend that people who install the 1200 kg JWT clutch and JWT FW don't seem to experience chatter as much of an issue. No surprise that something developed by the same place might be the best combo.
Mine has next to none, although you do notice more mech noise, that's just a no-brainer when you take out the dual-mass 30+ lb FW, and Aluminum also being less dense than steel, you transmit more noise in general.
Small price to pay for astoundingly good clutch performance, and at least in my case, the rev characteristics of the motor changed a lot, all for the better w/exception of sometimes dropping too low idle.
Old May 8, 2008 | 09:25 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
All lightweight flywheels emit the noise generally between idle and around 2400. It's especially noticeable between 1000 rpm and 2400 or so as you engage first gear from a dead stop. To some the noise is annoying to others, they don't care. The heavier the flywheel, the quieter it will be
Old May 8, 2008 | 09:51 AM
Gsedan35's Avatar
Gsedan35
Having been seen my desire to get a lightened flywheel come and go over the years and from lurking in posts where owners have commented about the noise, as usual Adams comments are spot on.
Old May 8, 2008 | 11:23 AM
eltness350's Avatar
eltness350
The Untouchable
my clutchmasters stage 4 clutch /lightweight flywheel barely makes any noise and would def handle the power u r running...
Old May 8, 2008 | 12:39 PM
gsazabi's Avatar
gsazabi
60K miles with your SC on STOCK clutch? Unbelievable..you need to upgrade NOW! Stock clutch is POS IMHO.
Like others said Aftermarket clutch will be able to put power down better and rev up and down faster. I too, would say that chatter is a small price to pay for extra performance. My JWT doesn't chatter all that bad either unless I'm in too low of a RPM in a wrong gear. I say you get something better than JWT though..it's nothing more than glorified stock clutch.
Old May 8, 2008 | 12:47 PM
Raskal96's Avatar
Raskal96
stick with the stock flywheel and take out the spare tire they weigh the same
Old May 8, 2008 | 01:00 PM
gsazabi's Avatar
gsazabi
Taking out the spare doesn't reduce rotating inertia resistance of the flywheel, doesn't it?
Old May 8, 2008 | 01:22 PM
chaparro78's Avatar
chaparro78
I always figured I would replace it when the stock one went out, it hasn't so it hasn't been a priority. Was either thinking of the JWT clutch & FW or the RPS clutch & FW. I don't know why, want to keep the combo the same brand though
Old May 8, 2008 | 07:55 PM
toy4two's Avatar
toy4two
nismo does it too, all of them do. I would highly recommend not doing this mod. Besides the annoying noises by ditching the dual mass stocker I find driveability sucks, you have to pay more attention starting off at stop lights, sure the faster reving is nice but my car is a daily driver.
Old May 8, 2008 | 11:02 PM
lbz's Avatar
lbz
My clutch is close to going, I'm planning on replacing soon. Was thinking about doing this mod but after thinking it over, my Z is my daily driver, no track time or anything like that, just "spirited" driving here and there.
I went ahead and bought stock and will leave the FW as is. Maybe by the time this new one is toast I'll be post warranty and ready to track the car and mod it accordingly. The savings from staying stock and having the install done by a good shop up the street instead of the dealer gives me $$ for an exhaust.
Old May 8, 2008 | 11:16 PM
geneses7's Avatar
geneses7
FIDANZA flywheel, stock clutch, lotsa rattle, **** it, who cares, heaps of throttle response!!! BOOYA
Old May 8, 2008 | 11:26 PM
gsazabi's Avatar
gsazabi
IMHO Nismo clutch/flywheel combo and JWT clutch/flywheel combo are absolutely perfectly suitable for daily driving, if not better than OEM.
Pedal travel is shorter therefore it's actually EASIER to engage 1st gear. Yes, sweet spot isn't as wide as stock so you it only allows little slip, but you shouldn't really be slipping the clutch in the first place anyway.
Unless you have Tilton setup or other stage 3/4 setup, these are perfectly drivable in a daily basis. Flywheel chatter is so overrated.
Old May 12, 2008 | 04:16 PM
350zHermosa's Avatar
350zHermosa
my slave cylinder just recently, friday, went out... at first i though it was the clutch, because it's about to go as well. but now it just sticks to the floor and i had to speed shift her about 40 miles to get it to my shop. and we've never replaced a z's slave cylinder before. has neone had any experience?
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
