Automatic 5AT tranny shut down?
Old May 15, 2008 | 04:40 PM
Fairly Z's Avatar
Fairly Z
Default Automatic 5AT tranny shut down?
So, I was on my way home from work and decided to take advantage of an opportune situation. There was no one on the road, and the road was newly wet with a very slight drizzle. So, I turned off my TCS and proceeded to spin my rear tires. While I had no trouble keeping the car under control, I did bring the engine to redline. After the wheels stopped spinning, it drove for a few seconds and then I lost my tranny. At first, I had it in tiptronic mode. So, I tried switching back to DRIVE, but it still had no affect. The transmission wouldn't grab, and the car just kept reving. Concerned, I pulled over to the side of the road and turned the car off. I let it sit for about a minute, turned it back on, and everything started working fine again.
My guess is that I redlined it for too long, and the computer automatically shut down my transmission to avoid any damage. Am I correct about this? Or, is there something else wrong here that I should be concerned with?
I -DID- use the search feature for this. I searched:
"Automatic shut down"
"Automatic lock out"
"5AT shut down"
"5AT lock out"
Forgive me if I should've searched more to find the answers, but I do hope you'll all be helpful and explain the situation to the best of your knowledge. Thanks!
By the way, my tranny is STOCK.
Old May 15, 2008 | 04:41 PM
phreaktor's Avatar
phreaktor
Design Engineer
Same happened to me. It's a failsafe.
Old May 15, 2008 | 04:46 PM
Fairly Z's Avatar
Fairly Z
Got it, that's what I thought. Thanks! Case closed.
Old May 15, 2008 | 06:58 PM
CSF's Avatar
CSF
oh man...i was hoping this would be the thread to shut up the "not one problem with AT in these threads!!!" guy
Old May 15, 2008 | 07:11 PM
phreaktor's Avatar
phreaktor
Design Engineer
FWIW, you shouldn't beat up on the AT's electronic shift...
Old May 16, 2008 | 10:31 AM
j.arnaldo's Avatar
j.arnaldo
HEY!!! NOT 1 PROBLEM WITH THE Auto trannies IN THESE THREADS!!! HAA!!!!!
GOT YOU, CSF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!
____________________________________________________________ _____
'O4 Touring Coupe/AT!!!/13k!!!/$2O,5OO!!!/NO FEATHERING, EITHER!!!!!!!!!!!!!!
HAAA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 16, 2008 | 01:56 PM
CSF's Avatar
CSF
lol...nuts
Old May 16, 2008 | 11:02 PM
gregom's Avatar
gregom
Was it staying in first gear only? You say it like it was in neutral or something.
Old May 16, 2008 | 11:16 PM
garym's Avatar
garym
Happens to me everytime I try to do a burnout with the brake slightly depressed. It won't let you go into 2nd gear, it jumps to neutral.
But all you have to do is shut the car all the way off and right back on, and it's fine.
I took it in to the dealer the first time and they told me not to do a burnout with my foot on the brake pedel. You can hammer it and let the tre s spin till they grab and it will be fine, just don't power brake it.
Old May 17, 2008 | 08:14 AM
coachk's Avatar
coachk
Or just do your burnouts in manual mode
Old May 17, 2008 | 10:53 AM
j.arnaldo's Avatar
j.arnaldo
Thumbs up
Just kiddin', CSF; I'm a firm believer in the "different strokes for different folks"
bit. It's just that, at my age--59--auto trannies are a BLESSING. You go ahead & knock yourself out with your 6MT!!!
Old May 17, 2008 | 02:45 PM
superchargedg's Avatar
superchargedg
Damn Noobs
+1 but im not over 50 yet.
Old May 17, 2008 | 02:51 PM
jcleary47's Avatar
jcleary47
LOL
Old May 18, 2008 | 11:17 AM
j.arnaldo's Avatar
j.arnaldo
Unless you die young---which I hope you don't---, you'll get there, too, kiddo! Maybe, just maybe, you'll end up appreciating ATs. Greetings...lol!!!
Old May 18, 2008 | 11:58 AM
superchargedg
Damn Noobs
I am almost there cause im 48.
Old May 18, 2008 | 12:34 PM
coachk's Avatar
coachk
5AT gets the TOP DAWG honor at ZDAYZ.....Take that you AT haters
Old May 19, 2008 | 02:35 AM
Z04's Avatar
Z04
+1
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
seagrasser
Oct 11, 2015 03:27 PM
AP350z223
Sep 8, 2015 04:38 PM
