AN fittings question
Old Jun 26, 2008 | 08:35 PM
Chad68's Avatar
Chad68
Default AN fittings question
The Moroso filter pictured below is avaiable in -8, -10 and -12 sizes.
Also pictured is the straight type AN hose end that I beileve I would need to attach the filter inline with the hose.
Question is what size AN fitting will fit a braided hose with a 3/8" (9mm) inside diameter? Is -8 equal to 3/8"?
I could just use one of the hose fittings that has a barb on the end but this would look much cleaner done right, instead of using hose clamps
Attached Thumbnails AN fittings question-moroso.jpg   AN fittings question-an-fitting.jpg
Old Jun 26, 2008 | 09:00 PM
Resolute's Avatar
Resolute
Army/Navy fitting and hose sizes are based on exterior diameter, not interior. Hence why mixing and matching between brands is not very wise, since not everyone uses the same interior dimensions for the same AN size. See if a local race shop could help you find a fitting that would match up well to your 3/8" line, or better yet, just buy some AN line of the right size.
Will
Old Jun 27, 2008 | 04:54 AM
go-fast's Avatar
go-fast
an fittings are directly related to internal diameter,it is broken down into 16th of an inch.-8 an is 1/2 inch,-4 an is 1/4 inch...ect.
Old Jun 27, 2008 | 04:58 AM
JasonZ-YA's Avatar
JasonZ-YA
what is that filter for?
-j
Old Jun 27, 2008 | 05:03 AM
Resolute's Avatar
Resolute
Yeah, you're right. Re-read what I wrote, and I'm backwards.
For a 3/8" inner hose, you'll need a AN-6 line and fitting. The external diameters are what varies between different brands, hence why fittings for Earls won't work so well with Aeroquip lines, even if they're the same AN size. Hence, what I was trying to say, that if you already have a braided 3/8" line, to check out a race shop if available for a fitting that will work best with that hose external diameter.
Will
Old Jun 27, 2008 | 07:55 AM
track1z's Avatar
track1z
I just went threw this with metric,AN,thread pitch and all the other crap.
Old Jun 27, 2008 | 07:59 AM
track1z's Avatar
track1z
This should help ya'll out if you need cheap parts
http://www.pegasusautoracing.com/?iorb=4764
Old Jun 27, 2008 | 08:00 AM
BrazenZ's Avatar
BrazenZ
If that is a gasoline/fuel line you are trying to plumb, be forewarned, you will probably have fuel vapor issues if your using stainless steel braided fuel line. The teflon vapor lock line is the only braided line that can eliminate odors in fuel injected fuel systems with 30<psi fuel pres. and it uses a different type of AN fitting.
Old Jun 28, 2008 | 06:36 AM
Chad68's Avatar
Chad68
Ok change of plans.
I'm going to use a different type of filter that has -6 AN male threads comming of the tube/body and I'm going to use the female AN -6 to -6 barb adapter (pic below) and just use clamps.
This -6 to -6 adapter (pic below) is the correct size for a 3/8" (9mm) inside diamter hose, right?
Attached Thumbnails AN fittings question-aer-fce1512_w.jpg   AN fittings question-sum-230101_w.jpg
Old Jun 28, 2008 | 12:03 PM
Resolute's Avatar
Resolute
Originally Posted by Chad68
Ok change of plans.
That's the less expensive and easy way to do it, and yes, 6 AN is 3/8" ID. AN sizes are designated in 16ths of an inch, so a 6 AN is 6/16", which equals 3/8".
Will
issyz
Jul 2, 2017 03:04 PM
